sunroof wont close
ok, i have a 90 crx si, the sunroof stoped working, when it moves, but it wont close on the passingerside, it closes on the driver side but the pass side stays up like i have it tilted........i wana take it off but i dont kno where to begin, anybody have any good sunroof removal links?? or kno who got em, did a search didnt find much
From: I told you to wait in the truck in Texas, United States
in the FAQ you will find this link:
http://mirror.rivendel.nu/crxc...f.pdf
In with your tire tools there should be a wrench to help close it..
There is a plug in the headliner you remove,then stick the tool
in and close manually..
The sunroof on my 88 CRX Si had the same problem. I took the sunroof apart to find that a plastic part had broken. It's the plastic piece that is integrated with the sunroof cable assembly that connects to the metal lift up link. That's the part that tilts the sunroof panel up and down. To remove the sunroof, you have to remove the headliner first. Then it's just a matter of disconnecting the drain tubes and removing a few screws and bolts. After that, you need to remove the panel from the assembly to get to the part. I replaced the entire cable assembly, which include the broken plastic piece, with one off of a sunroof that I bought from someone who wrecked his car. The entire repair took me about an hour. Good luck, and get a repair manual if you can. It helped me a lot.
i tried closing manually wont close, and it still works, but it goes back at different paces almost like its bending. tried forcing it down with some muscle an still couldnt put it down. ok well i guesss i'm gona have to grab me a manual thanx
crxaddikt
Dec 1, 2012 03:28 PM
thawley
17
Dec 13, 2004 08:47 AM
