CRX D16Z6 swap i gots ?'s
im doing a d16z6 in a 90crx si has anyone used the obd0 to obd1 conversion harness? will it make it plug and play? i need the swap to be easy and not take long...
you don't really need the Z6 harness. Buy the OBD0-OBD1 conversion harness from http://www.jkobd.com. All you will need to do is add the VTEC wires to their components (the wire ends off the ECU are provided on the conversion harness, all YOU need to do is connect them appropiately)
The only thing the D16z6 harness is good for are the plug clips. Thats pretty much it. (Distributor, 4wire o2 sensor)
-Jon
-Jon
Jonathan_ED3
Jul 29, 2005 09:29 PM
madswapper
Mar 28, 2005 07:51 PM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
