Rim size for wilwood big brake kits
Old Mar 18, 2005 | 10:37 AM
noob with an RS's Avatar
Default Rim size for wilwood big brake kits
Will 16 inch wheels fit over a set of wilwood brakes? I know the size of the disc is 12.19 inches, but not sure if the caliper will clear.
Old Mar 18, 2005 | 11:31 AM
Mike_C's Avatar
depends on the wheel.
Old Mar 19, 2005 | 07:32 AM
jmk2888's Avatar
Default Re: (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">depends on the wheel.</TD></TR></TABLE>
& offset.
Old Mar 19, 2005 | 10:38 AM
Mike_C's Avatar
Default Re: (jmk2888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 &raquo;</TD></TR><TR><TD CLASS="quote">& offset.</TD></TR></TABLE> well yeah, the wheel has a specific offset. that is kind of understood... so it depends on the wheel.
Old Mar 20, 2005 | 01:21 PM
h22John's Avatar
Default Re: Rim size for wilwood big brake kits (noob with an RS)
Yeah it depends. My buddy had 16in gram lights on his hatch with the brake kit and he had to notch the caliper to get it to fit.
Old Apr 1, 2005 | 10:35 PM
one_stinky_bum's Avatar
so would +40 offset work? I've got 17"s by the way
Old Apr 5, 2005 | 02:59 PM
Perpetual Concepts's Avatar
Default Re: (one_stinky_bum)
Yes, if you have a +40 offset with 17's it will work. We ran that kit on 16" with a +40 offset and it just barely cleared.
Old Apr 6, 2005 | 04:00 PM
Default Re: (Perpetual Concepts)
cool
Old Apr 7, 2005 | 11:38 PM
JDMHN8's Avatar
These all fit:
Old Apr 9, 2005 | 08:00 PM
SuckMyDOHC's Avatar
Default Re: (JDMDA9)
hey JDMDA9, those rims you have look like 16's, whats the offset?
Old Apr 9, 2005 | 09:22 PM
JDMHN8's Avatar
Default Re: (SuckMyDOHC)
TE37s +42mm
Enkei ER01s +38mm
Rota Shitass +40mm
All fit with room to spare... TE37 is the tightest fit, though...
Old Apr 9, 2005 | 09:53 PM
SuckMyDOHC's Avatar
cool thanks... so the wilwood kit shouldn't be a problem with my 16" slipstreams then
Old Apr 10, 2005 | 12:19 AM
AutoRnD's Avatar
Rim Guru
I wanted to chime in real quick cause i noticed it wasn't explicitly stated but briefly mentioned. For reference, I do wheel and brake caliper clearances for a living with Endless USA, lol, so I thought I might be able to reiterate what's kinda been touched on above.
Variables involved with Brake Caliper clearance.
1. Spoke Architecture, the design of the spoke of the wheel. The more of a knuckle the spoke has near the rim edge and the lesser lip it has, will result in more caliper clerance. duh you guys already know that but had to be said.
2. Pad height/Disc thickness of the wheel chosen. The thicker the "back pad" or mating part of the wheel is the more area you will have for a caliper as well.
While many people do refer to offset with brake clearance it really is an arbitrary value. You can have the exact same wheel design, diameter, width, and offset but one wheel clears the brakes and the other does not.
A lot of times you can't find information on pad heights and offsets so you kinda have to know what "style" of wheel to look for. That's why i mentioned "knuckle" and "less lip".
An example of a wheel with no lip, good caliper clearance, and very pretty high offset.
Now you can get this same wheel in the same offset, but with more lip. Because of the lip it will lose caliper clearance.
So to put some misconceptions to rest, don't rely on offset. If it is a one piece wheel and doesn't have "pad" options, then do what you guys are doing and make a list of the wheels which are known to fit that exact wheel.
The majority of aftermarket Brake Systems should come with a CAD drawing of sorts showing the measurements to take against your wheel to check if they will work or not. I've had many a clients who have purchased brakes only to find out they have to buy some ungodly custom built expensive *** wheels.
I'll see if I can get an example of a drawing we use for Endless up here so you guys can see what i'm saying. If you get these measurements and already have your wheels then it's the most sure fire way to get a reliable answer.
Hope this helps you guys out or anyone that references it. I didn't get into too much detail cause it would get overbearing so best of luck. We don't carry Wilwood so i don't have those measurements but your dealer should.
Old Jun 10, 2005 | 11:41 PM
z168's Avatar
Default Re: (Endless_USA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endless_USA &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to chime in real quick cause i noticed it wasn't explicitly stated but briefly mentioned. For reference, I do wheel and brake caliper clearances for a living with Endless USA, lol, so I thought I might be able to reiterate what's kinda been touched on above.
Hope this helps you guys out or anyone that references it. I didn't get into too much detail cause it would get overbearing so best of luck. We don't carry Wilwood so i don't have those measurements but your dealer should.</TD></TR></TABLE>
good info! im having problems with my brembos. i have to stick with 18"s
just yesterday I looked at a set I won on ebay. 18x7.5 45mm offset (should be ok for a gen5 accord right?) but no it touches the caliper
Old Jun 11, 2005 | 11:14 PM
GetawayInMoscow's Avatar
Default Re: (z168)
Do they fit behind slips? anyone know?
MessGSR
Honda Civic (2006 - 2015)
15
Dec 8, 2007 07:32 AM
Kapetan
10
Jun 8, 2006 09:45 AM
alternativeauto
Honda S2000
Apr 4, 2006 05:40 AM
volkdlr
17
Nov 23, 2004 08:56 AM
01-0720
Acura NSX
Apr 18, 2004 01:30 PM
