What pistons and rods do you guys run with your all motor builds
im running factory rods that i have had shootpeened and i use arp 8mm rod bolts as for pistons in b18 non vtec builds i run 81.5mm p30 pistons wich leaves you witha low enough compression to be streetable and run a beefy cam ie crower 404 but if you want to build an all motor unstreetable motor run ctr pistons and crower 405s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER »</TD></TR><TR><TD CLASS="quote">Im just curious to see what piston and rod combo you guys are running</TD></TR></TABLE>
custom crower made for Endyn ... almost as light as titaniums but without the galling factor.
eagle rods on customers cars and some of my street engines.
Greg
Greg
Crower stell billet+ Je or Cp or Ib Spec pistons... still deciding on pistons, last setup was Crower+ Je though
Very Emergency!!
i have eagle rods w/arp bolts and cp pistons in my setup. should be running this weekend. i do know that the cp pistons seem to have thicker ring lands then my old je's that i melted and the gas ports are lower down on the piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller.91.HB »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation »</TD></TR><TR><TD CLASS="quote">
Aluminum rods with custom pistons</TD></TR></TABLE>
Baller
hopefully not on your street motor
Baller
It depends on how crazy the setup needs to be. For most street cars, I try and use balanced and/or cryotreated OEM Honda stuff. For everything else, I'm loyal to CP pistons, but I've never been loyal to a rod manufacturer.
Street car: IB Spec Wiseco 81.5mm with 5 cc dome and Crower rods.
Drag car:IB Spec Wiseco 86mm "Ultimates" and custom Cunningham rods.
I have RLZ Wiseco pistons and +.137" Eagle rods in my GSR motor.
I also have B16 pistons and LS rods in my LS/VTEC motor.
