a stock ecu on semi built N/A?
Old Mar 18, 2005 | 07:09 AM
B16EKruger's Avatar
Default a stock ecu on semi built N/A?
im currently building my B16 for my ek and im makin it obd2 cuz i have a jdm obd2 b16 ecu (not the si, this one is 96-98). im not too familair w/ ecu's, so would it be bad to run a stock ecu on a worked motor? i was readin about hondata, but i was alittle confused on how it works. i dont know that much about ecu's so i just need to know what i should to do it. here's what im puttin in:
B16 block
CTR pistons
balanced crank
CTR cams
Skunk2 cam gears
ITR intake valves/springs
mild p/p
skunk2 manifold
68mm TB
GSR head
AEM fuel pressure regulator
Old Mar 18, 2005 | 08:00 AM
Grand's Avatar
for that build i would highly advise tuning use uberdata if money is an issue but protect your investment and tune it there is also more power to be made by tuning
creizlein
27
Feb 20, 2017 07:25 PM
BlankitoEG6
Apr 17, 2010 02:52 PM
88 EF Hatch
Jul 14, 2009 01:24 PM
Dev15Bizz
Apr 20, 2009 03:06 PM
Yellow Dragon
Jul 21, 2002 11:34 PM
