What heat range plugs for High Compression JDM ITR
I have a 96 b18C-R with a spoon s layer headgasket and supertech flat top valves. I keep getting mixed answers about what heat range I should use. Here's some more info about my motor:
Skunk2 stage 2 cams, skunk 2 titanium valve springs and retainers, skunk2 adjustable cam gears, rc 310 injectors, AEM fpr, hondata im gasket, Toda 421 header, walbro 355 lph fuel pump, hondata s100 P28 ecu.
Thanks for your help!
Thanks! Does anyone know a good place to purchase them? All the local auto parts stores only sell the 7's. Should I stick to the double platinums or the iridiums? They both cost the same. I heard the iridiums last longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote"> I heard the iridiums last longer.</TD></TR></TABLE>
That's correct for the versions with Iridium tip + platinum ground.
Ok, I just got off of the phone with NGK Technical Support. They recommended that I get the BKR8EIX iridium plugs over the double platinums. I guess I'll try them out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">"8" range???</TD></TR></TABLE>
Yes 8. It's a JDM ITR motor that requires the 7 range. I bumped the compression with a 2 layer spoon head gasket and supertech flat top valves. I keep getting mixed answers on which plugs to get since the compression bump. Some say 7 most say 8. I guess there's only one way to find out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">Ok, I just got off of the phone with NGK Technical Support. They recommended that I get the BKR8EIX iridium plugs over the double platinums. I guess I'll try them out.</TD></TR></TABLE>
Don't get that one. That's the version without platinum tipped ground, just like the Denso IK plug.
If you want Iridium center + platinum ground, get the IFR7G-11 or IFR8G-11 if this one exists.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">
If you want Iridium center + platinum ground, get the IFR7G-11 or IFR8G-11 if this one exists.</TD></TR></TABLE>
They don't make a IFR8G-11. Are there any other choices? Will the 7G-11's be ok with my compression? This is becoming a pain in the ***!
going a little off topic now but:
say... if you have tuned the A/F ratio on your car... with 7degree plugs and you decide to use 8 degree plugs... would you gain/lose/even power?
white_n_slow
16
Apr 15, 2006 09:05 PM
Thrashin
Nov 20, 2004 11:11 AM
Boost2NA
Mar 22, 2004 11:21 AM
