wire herness
im plannning on switching out my trans and posibly my engine as well and i will have to switch the wire harness out. this seems like a pretty easy thing to do, to me you just plug in wires but im not to familiar with electrical work so if anyone has any info or tips it would be appreciated
LS or GS-R Tranny
Transmission Linkages
Transmission Mounts
Clutch
Flywheel
Pressure Plate
5 Speed Pedals
Manual ECU
Manual Gauge Cluster (optional)
Shifter and Shift Boot
Clutch/Slave Cylinders
Clutch Reservoir
Matching Throttle Cable for the Pedal Set
hydraulic lines
Intermediate Shaft
Upper transmission mount
That can start you out...Good Luck..
Transmission Mounts
Clutch
Flywheel
Pressure Plate
5 Speed Pedals
Manual ECU
Clutch Reservoir
hydraulic lines
Intermediate Shaft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMC »</TD></TR><TR><TD CLASS="quote">YOU CAN USE YOUR STOCK AUTO HARNESS JUST DONT USE THE WIRES TO THE AUTO TRANNY....</TD></TR></TABLE>
Correct, but it does clutter up the engine bay to have all the extra plugs hanging out.
alexsracing
Oct 9, 2005 08:22 AM
