91 CIVIC W/ 1.8 LS ---- WHAT HEADER TO ORDER?????
Old Mar 18, 2005 | 03:20 AM
rtwef9's Avatar
Default 91 CIVIC W/ 1.8 LS ---- WHAT HEADER TO ORDER?????
I HAVE A 91 CIVIC WITH A LS MOTOR, GREDDY P.E. EXHAUST. I HAVE A B16A MANIFOLD ON IT NOW AND IT FITS PERFECT. I ORDERED A HEADER FOR A 92-93 INTEGRA LS, AND THE DOWN PIPE IS ABOUT AN INCH TOO LONG. ANY SUGGESTIONS WOULD GREATLY BE APPRECIATED!!
Old Mar 18, 2005 | 03:28 AM
PaImportTuner's Avatar
Default Re: 91 CIVIC W/ 1.8 LS ---- WHAT HEADER TO ORDER????? (rtwef9)
dc 4-2-1, kamikaze 4-1 this one is specifically made for a b series in EF, hasport also.
Old Mar 18, 2005 | 04:00 AM
quicksol95's Avatar
Default Re: 91 CIVIC W/ 1.8 LS ---- WHAT HEADER TO ORDER????? (PaImportTuner)
4-2-1 header
only a few 4-1 work unless you have a traction bar or notch your front cross member
Old Mar 18, 2005 | 04:01 AM
rtwef9's Avatar
FOR WHAT YEAR THOUGH, 90-91 IS DIFFERENT FROM 92-93
Old Mar 18, 2005 | 04:13 AM
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtwef9 &raquo;</TD></TR><TR><TD CLASS="quote">I HAVE A 91 CIVIC WITH A LS MOTOR, GREDDY P.E. EXHAUST. I HAVE A B16A MANIFOLD ON IT NOW AND IT FITS PERFECT. I ORDERED A HEADER FOR A 92-93 INTEGRA LS, AND THE DOWN PIPE IS ABOUT AN INCH TOO LONG. ANY SUGGESTIONS WOULD GREATLY BE APPRECIATED!! </TD></TR></TABLE>
think about it... order one for the b16 if it fits perfectly.
Old Mar 18, 2005 | 04:24 AM
rtwef9's Avatar
Default Re: 91 CIVIC W/ 1.8 LS ---- WHAT HEADER TO ORDER????? (limpy)
NO CIVIC CAME WITH A B16, SO ITS A LITLE HARD TO LOCATE A HEADER FOR A 91 DOHC VTEC CIVIC
Old Mar 18, 2005 | 04:33 AM
Default Re: 91 CIVIC W/ 1.8 LS ---- WHAT HEADER TO ORDER????? (slow90hatch)
the kamikaze 4-1 clears like if not better than a 4-2-1 basically looks like a tubular equal length turbo manifold and goes into 1 tube downpipe half way down the block.
*think of an STD manifold with a straight pipe connected in place of cat to bottom half of manifold.
Old Mar 18, 2005 | 09:59 PM
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtwef9 &raquo;</TD></TR><TR><TD CLASS="quote">NO CIVIC CAME WITH A B16, SO ITS A LITLE HARD TO LOCATE A HEADER FOR A 91 DOHC VTEC CIVIC</TD></TR></TABLE>
no civic came with an ls w/a b16 header either.... think about it man.... order the one for the b16(it will come in the same exact size as the one on your car now...that happens to fit perfetcly) order one for the 99-00 civic si, or the 95 del sol si... it is the same thing.
Old Mar 19, 2005 | 03:37 AM
rtwef9's Avatar
very good... but my car has a ls motor with a b16 stoch manifold that fits perfect because the b16 motor has the ls header on it in a da!!
Old Mar 19, 2005 | 04:14 AM
92integra_gs's Avatar
if its an inch long get the 90-91 headers it should be shorter.... i would go either kamikaze or DC
Old Mar 19, 2005 | 04:22 AM
rtwef9's Avatar
Default Re: (92integra_gs)
THE STOCK LS MANIFOLD(1990) WAS TOO LONG THATS WHY I LEFT THE B16 MANIFOLD ON THE LS MOTOR
Old Mar 19, 2005 | 05:03 AM
davens's Avatar
I was in the same boat...B18b w/ 90-91 header...it was too long.
I took it to a muffler shop and had them cut and flare the end. Fit it correctly and clamped it. Drove it to the muffler place and they welded it. Cost me $20 all said and done.
Old Mar 19, 2005 | 06:05 PM
limpy's Avatar
Default Re: (davens)
ORDER THE 99-00 CIVIC SI HEADER.... IT IS THE SAME DAMN LENGTH AS THE STOCK B16... PLEASE READ. I HAVE A 99-00 SI DC HEADER ON MY CRX WITH AN LS SWAP AND IT FITS FINE.
ITA50
May 25, 2007 10:49 AM
chirp the 1-2
13
Feb 20, 2006 05:50 PM
civickiller
Nov 25, 2005 10:53 AM
rtwef9
Mar 20, 2005 06:18 PM
