valve cover gasket leak
just replace it dude.....like 25 bucks from honda get OEM parts for all your gaskets BTW....make sure to torque the nuts on the VC only to 7lbs...you may be over tightening....hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tampa94lsteg »</TD></TR><TR><TD CLASS="quote">.make sure to torque the nuts on the VC only to 7lbs...you may be over tightening....hope this helps</TD></TR></TABLE>
yeah a lot of people break the stud because of overtightening, they're not as tight as you think.
