Suspension & Brakes Theory, alignment, spring rates....
Si shocks on Teg
Old Mar 17, 2005 | 08:06 PM
Mr_Moos's Avatar
Default Si shocks on Teg
will 99-00 Si shocks work on a 99 Integra GS w/ Skunk 2 coilovers
Old Mar 17, 2005 | 08:49 PM
purplegsr's Avatar
Default Re: Si shocks on Teg (Mr_Moos)
Somewhat, the fronts will work fine - they are the same size as the 94-01 Integra/92-95 Civic shocks and will fit into your stock front drop forks. However, the rears will not work (the fork is too narrow for the Integra rear LCAs), so you can either swap in some aftermarket EK Civic LCAs (will need a connection for the Integra sway bar and you have to worry about the different length of the EK LCAs affecting your alignment) or shave a bit off of the bushing to make it thinner and able to fit into the EK rear forks.
Old Mar 17, 2005 | 09:25 PM
Mr_Moos's Avatar
Default Re: Si shocks on Teg (purplegsr (Exospeed))
aight thanks
Old Mar 18, 2005 | 08:11 AM
94eg!'s Avatar
#1 Super Guy
Loved
EK rear LCAs are not going to work on your DC. They are about an inch longer EACH. Imagine all the havok that would play on your rear suspension...
I have "heard" that you can have the EK's lower shock mount bushing pressed into your DC LCA. That would be the best idea (if your really set on using EK shocks), but grinding will work too...
Trixiem
Suspension & Brakes
Feb 4, 2011 11:57 AM
uenolove
Jan 28, 2009 01:03 PM
tronic
Suspension & Brakes
Mar 21, 2007 02:37 PM
Mewgen
Suspension & Brakes
May 18, 2006 07:37 AM
t_c_l_6
Suspension & Brakes
Jan 30, 2006 04:19 PM
