problem with gs-r.. its pretty scary
i feel like i loose power after about 7k rpm everytime i get to around that area my accelerator pedal starts vibrating. it feels like the floor is about come out from under me. any of you gugys ahd a problem liek this. i tried searching but nothing thanks again
we need more details.... do u here any vibrations? what are your mods to the car? mileage? maintanence? the more info the more help we can give...
motor mount possibly? does the car shake at all? u said the floor board and the floor board is unibody with the car so if thats moving then the rest of the car is. hows the inserts(rubber) on the motor mounts? check for light cracks or signs of wear. possibly something to do with wheel balance. its something to do with balance period. something gets off balance in a certain area an causes a movement. like u can do 70 on some tires and be shakin like a **** then u hit 75 and its all good. same with motor mounts and rpms, torquing the motor around..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 »</TD></TR><TR><TD CLASS="quote">i feel like i loose power after about 7k rpm everytime i get to around that area my accelerator pedal starts vibrating. it feels like the floor is about come out from under me. any of you gugys ahd a problem liek this. i tried searching but nothing thanks again</TD></TR></TABLE>
hmmm..like green e-cilips from F&F??? lmao
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 »</TD></TR><TR><TD CLASS="quote">hmmm..like green e-cilips from F&F??? lmao</TD></TR></TABLE>
no one here likes the tuna *******!!!!
i hardly doubt it is an oil problem or a rotor problem, but i do have one suggestion.
take this to the tech forum because these responses are belligerent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 »</TD></TR><TR><TD CLASS="quote">warped rotors? </TD></TR></TABLE>
that would be when he presses the break pedal down, what are you mods? if you have an after market intake manifold make sure the throttle camble isnt wobbling around under the hood...if its vibrating up against the hood this might cause that "vibrating" feeling in the pedal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinteg777 »</TD></TR><TR><TD CLASS="quote">that sucks when get it done</TD></TR></TABLE>
enRish > you
enRish > you
VTEConly
Jun 24, 2006 04:48 PM
T_bones
Sep 5, 2005 03:11 PM
