Installing 89 si cluster in a dx hatch
Old Mar 17, 2005 | 05:16 PM
WH0R3nEF9's Avatar
Default Installing 89 si cluster in a dx hatch
Im installing an 89 si cluster on a friends 89 hatch dx and have some questions. I was told this was a direct plug and play. There are two plugs for the dx cluster and only one for the si. How does that work? Do we need extra parts to do the swap. Any help would be killer. Thanks in advance
Old Mar 17, 2005 | 05:31 PM
JapJunkie's Avatar
Default Re: Installing 89 si cluster in a dx hatch (1SiKTeG)
WTF? only one plug. There has to be 2.
Old Mar 17, 2005 | 05:34 PM
T-Mo's Avatar
go to http://www.fourthgenhatch.net
under 'technical' go to 'how to'
It shows you haw to replace the Si gaige cluster w/pics
Hope that helps!! For those that remeber the site as ".com" it is now ".net"
Old Mar 17, 2005 | 05:43 PM
JapJunkie's Avatar
Default Re: (T-Mo)
The site doesnt work for me
Old Mar 17, 2005 | 05:45 PM
WH0R3nEF9's Avatar
Default Re: (T-Mo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Mo &raquo;</TD></TR><TR><TD CLASS="quote">go to http://www.fourthgenhatch.net
Hope that helps!! For those that remeber the site as ".com" it is now ".net" </TD></TR></TABLE>
That site no longer exists or is under construction. Or maybe my computer just sucks. If you can copy and paste the direct link, please do. I cant figure this out. Thanks again
viper_2_4's Avatar
it plugs in......same as the old one..
Old Mar 17, 2005 | 05:47 PM
WH0R3nEF9's Avatar
Default Re: Installing 89 si cluster in a dx hatch (JapJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie &raquo;</TD></TR><TR><TD CLASS="quote">WTF? only one plug. There has to be 2.</TD></TR></TABLE>
Im looking at it right now, there is one blue place to plug in on the new si piece. Do to take a piece off the dx and use it with the si? there is a silver rod that comes out about an inch or so, but i think thats for the tach. I've never sone this before and dont really know what going on, Im an integra guy. Anyone else have a clue??
Old Mar 17, 2005 | 05:48 PM
T-Mo's Avatar
as said before, there is nothing to figure out it plugs in the same as the one you take out!!!!!
Old Mar 17, 2005 | 05:49 PM
WH0R3nEF9's Avatar
Default Re: (viper_2_4)
Like i said before, the si has one plug and the dx has two. Do i only need to plug one it and it'll work?
Old Mar 17, 2005 | 05:51 PM
WH0R3nEF9's Avatar
Default Re: (T-Mo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Mo &raquo;</TD></TR><TR><TD CLASS="quote">as said before, there is nothing to figure out it plugs in the same as the one you take out!!!!!
Dude, there is two plug for the dx and only one plug in for the si. I cant make it any more clear than that. I appreciate your help though, dont get me wrong. Im just frustrated.
Old Mar 17, 2005 | 05:57 PM
T-Mo's Avatar
post pics!! I have done this cluster swap 3 times now. Keep trying the site. It takes a second to load up because its a mirrored site of the original site. USE the one thats ".net"
other than that I can try to find some other help for ya. Try this http://www.gutterslide.com/fou....html
Old Mar 17, 2005 | 06:20 PM
WH0R3nEF9's Avatar
Default Re: (T-Mo)
i got that site up. i think we can get it from here. thanks a bunch
Old Mar 18, 2005 | 09:22 AM
WH0R3nEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viper_2_4 &raquo;</TD></TR><TR><TD CLASS="quote">it plugs in......same as the old one..</TD></TR></TABLE>
i tried installing it last night and i guess it does have two plugs. im an idiot!! But, the install still didnt work. In the middle of the back of the si cluster (over the light bulbs) there is a plastic piece with a blue plug and the dx (4speed) doesnt have a plug for that one. When we turn the car over, the check engine light was on, the tach didnt work, and none of the start up lights came on (oil, bat, seat belt etc.). I was told this was plug and play. What do i need to complete this install and make it work? PLEASE HELP!!!
Old Mar 22, 2005 | 12:14 PM
Shelton's Avatar
Default Re: (1SiKTeG)
damn i did the swap on my eg with and ex cluster and i believe i used the ex cluster harness aswell adn it was plug an play if ef's r the same in that nature then u might need the si harness
Old Mar 22, 2005 | 01:55 PM
Deetz's Avatar
Crazy Honda Guy
There are 2 different Si cluster out there. Make sure you get the one that makes the mfg of your car. The 2 styles are NS and ND.
I kill the spelling on this, but here goes:
ND- Nippon Denzo
NS- Nippon Seikki
Old Mar 28, 2005 | 07:11 AM
WH0R3nEF9's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">There are 2 different Si cluster out there. Make sure you get the one that makes the mfg of your car. The 2 styles are NS and ND.
ND- Nippon Denzo
NS- Nippon Seikki</TD></TR></TABLE>
How can i tell which one it is? I dont know much about efs, but there are two plugs in the back. one on each side, but there is one in the middle too. Its a smaller blue plug. There is no plug on my friends car for the middle one. When we tried it, the tach didnt work and the check engine light came on. Non of the other lights worked either. example: seat belt, brake and all that crap. Whats the middle blue plug and why doesnt his car have this? His car is the basic model, dx 4-speed. HELP! What does he need?
Old Mar 28, 2005 | 03:55 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKTeG &raquo;</TD></TR><TR><TD CLASS="quote">
How can i tell which one it is? I dont know much about efs, but there are two plugs in the back. one on each side, but there is one in the middle too. Its a smaller blue plug. There is no plug on my friends car for the middle one. When we tried it, the tach didnt work and the check engine light came on. Non of the other lights worked either. example: seat belt, brake and all that crap. Whats the middle blue plug and why doesnt his car have this? His car is the basic model, dx 4-speed. HELP! What does he need?</TD></TR></TABLE>
Easy! At the bottom of the speedometer there will be a little stamping with either NS or ND. Just make sure they are the same mfg for it to work properly.
Old Mar 28, 2005 | 05:29 PM
Cory man's Avatar
Default Re: (Deetz)
Are you sure its an 89 Civic Si cluster? The 89 crx Si cluster WILL NOT work with any Civic model. If you plug in an 88 CRX Si cluster into an 89 Crx Si only half of the cluster will work. I know this from experience with selling and testing Si clusters to sell on ebay. Easiest way to identify an 89 Crx si cluster from an 89 civic si cluster is the seatbelt warning on the crx cluster is between the fuel and temp gauges. If possible snap some pics of the cluster and I can tell you what model it came from. hth
civicb16eg
Jun 26, 2008 07:37 AM
rxmx
23
Jan 15, 2007 07:23 AM
ef9love
Jul 15, 2006 02:13 PM
NightHawkC5
10
May 23, 2006 04:42 AM
608 Gangsta
12
Jun 12, 2004 06:04 AM
