Good Replacment plug? what are you using?
Old Mar 17, 2005 | 01:11 PM
Collateral's Avatar
B A N N E D
Default Good Replacment plug? what are you using?
I need to replace the plugs on my Type R and wanted to know what you guys are running and think is good?
Stock O.E's good?
Thanks
Chris93Si's Avatar
Default Re: Good Replacment plug? what are you using? (Collateral)
Stock NGK platinums
Old Mar 17, 2005 | 01:23 PM
ceasar of mgineering's Avatar
▓spam and rice▓
Default Re: Good Replacment plug? what are you using? (Chris93Si)
https://honda-tech.com/zerothread?id=1166619
Old Mar 17, 2005 | 01:24 PM
Collateral's Avatar
B A N N E D
Default Re: Good Replacment plug? what are you using? (ceasar of mgineering)
Thanks Chris and Ceaser
Old Mar 17, 2005 | 01:43 PM
Bbasso's Avatar
Stock plugs get a from me.
Old Mar 17, 2005 | 05:37 PM
EK9Civic's Avatar
NGK Iriway 7 here
Old Mar 17, 2005 | 06:03 PM
jeremy.'s Avatar
Default Re: Good Replacment plug? what are you using? (EK9Civic)
denzo iridiums....ik21
Old Mar 17, 2005 | 06:23 PM
wildz's Avatar
Iriway 7 here too
Old Mar 17, 2005 | 07:18 PM
DsITR's Avatar
NGK coppers here. Just replace them more often then the platinums.
Old Mar 17, 2005 | 07:24 PM
MGITR's Avatar
We use OEM Honda part # 98079-57148 for the ITRs we work on. OEM Honda/NGK quality, inexpensive, 7 temp range, etc.
Old Mar 17, 2005 | 07:53 PM
Opie's Avatar
NGK Iridium Temp 7's. 20k miles and still looking good
Old Mar 17, 2005 | 08:25 PM
HYREV2NR's Avatar
I like the NGK V Power plugs only one stage cooler. They only run about 8 bucks for a set.
Old Mar 17, 2005 | 08:36 PM
Mike K's Avatar
Default Re: (HYREV2NR)
why are you guys using 7 heat range? the 6 heat range is more than adequate for up to 11.5:1 compression, unless you live in the desert.
Old Mar 18, 2005 | 08:48 PM
MGITR's Avatar
Default Re: (Mike K)
We are in Utah, which gets to over 100 in the summer. We use a 6 in the winter.
Old Mar 18, 2005 | 10:16 PM
DC2IntegraTypeR's Avatar
I've heard good feedback about the OWS Uber Power plug
http://www.ows.com.au/products_sparkplugs.html
Old Mar 18, 2005 | 10:20 PM
SwiftTypeR's Avatar
New User
Spitfires
Old Mar 19, 2005 | 04:07 AM
Rene M's Avatar
Default Re: (SwiftTypeR)
SH did a nice write up on plugs... http://www.superhonda.com/foru...29793
Old Mar 19, 2005 | 05:00 AM
DutchITR1689's Avatar
Default Re: (Rene M)
This one is a good replacement: http://www.sparkplugs.com/resu...11175
This IFR7G-11 NGK Iridium plug (IFR, not IX plug) has platinum tipped ground electrode, the Denso IK Iridium hasn't.
Stock double platinum is also good. http://www.sparkplugs.com/resu...13353
Stock JDM B18C plug = PFR7G-11
Old Mar 21, 2005 | 08:09 AM
Dforce's Avatar
That's what she said!
Default Re: Good Replacment plug? what are you using? (ekay_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">denzo iridiums....ik21</TD></TR></TABLE>
ditto.
Old Mar 26, 2005 | 01:11 PM
▓spam and rice▓
Default Re: Good Replacment plug? what are you using? (Dforce)
ik27
sikcrx80
Mar 28, 2004 08:50 PM
Bbasso
Dec 11, 2003 08:50 AM
hYpE-R-29
Dec 10, 2003 09:38 AM
faultofhumanity
15
Sep 22, 2003 09:34 AM
MintyDip
Jul 1, 2002 12:42 PM
