oil in plug cylinders
The last two times i changed my spark plugs I found oil in where the plugs are. Is this a bad sign, how would oil get in there, what should i check for?
the last time i changed th eplugs i also changed the valve cover gasket and the ring gaskets around each of the plug cylinders, but some oil still got in there.
From: I told you to wait in the truck in Texas, United States
What engine do you have?
Some engines,like the D16a6 or D15b2 also have
o-rings under the rocker arm assemblies..
oops i had that in the title and removed it for some reason...
JDM b16 g1 from an SIR.
I thought th enew ring gaskets that go around the plug cylinders would stop any oil from getting in there but there was still some when i checked. The new gaskets fit very snug.
look here. the leak is from 99% your spark plug tube seals..which is what ya bought. they dont need any gasket sealer or any silicone liquid gasket. when u install them make sure your valve cover is clean of oil and the surface on the valve cover(where the seals sit on) o. and the other 1% is a cracked head in the plug hole!( for that to happen id win the lotto!)
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
mailforjon
Aug 5, 2002 04:34 PM
