Lowered Car w/Springs - Now why is it so bouncy?
Well I searched for 15 some odd minutes & couldn't find crap so here goes...
I just got the Neuspeed Race Springs, it dropped me 2" in front & 1.75" in the back & the ride is really bouncy. I am running stock shocks/struts b/c I wanted to see if they would handle it ok, & apparently they do not lol. Im thinking of getting a set of KYB AGX Adjustable's & maybe this will fix it. What do you guys think? Whats making it bounce so much? Bad shocks/struts? thanks alot, i appreciate it!
From: hittin corners so hard you can taste my rims..
spring rates... and worn struts.
the spring rates arn't that big of a deal, but the fact that you've lowered your strut more, you loose that much travel, and your seals could be bypassing alittle.
you need new struts.. it'll make a HUGE differance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_RS »</TD></TR><TR><TD CLASS="quote">No all we did was just remove the old spring, & put in the new one. That was all lol</TD></TR></TABLE>
id cut your bump stops down and see how the ride is then(unless you really want new struts). i got stock struts with neuspeed race springs, thats all i ran for the last 4 years on my cars. when you lowerd the car you shortend the travel of the strut(im sure you know this) but when you dont cut the stops they at that closer to bottoming out on the strut, so without cutting these at least in half you'll still get a bouncy ride with new struts because it will still be bottoming out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patmcd »</TD></TR><TR><TD CLASS="quote">Lowered car + stock shocks = crappy ride. Get some better shocks and your ride should improve.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DontBlink »</TD></TR><TR><TD CLASS="quote">did you cut your bump stops down at all?</TD></TR></TABLE>
Do this when you get new shocks unlesss you get a full strut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin85193 »</TD></TR><TR><TD CLASS="quote">get some koni yellows :0
I have koni yellows/gc coilovers w/ srr rear lca's.. ride is nice
What spring rates you get?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy »</TD></TR><TR><TD CLASS="quote">
What spring rates you get?</TD></TR></TABLE>
I just got the off the shelf rate. I can always upgrade :0
[QUOTE=Built B16A]spring rates... and worn struts.
[QUOTE]
man.... you really should get shocks when you dropp your car.... it's highly recommended. and like i said recommended, not a neccesity.
[QUOTE]
vitrox
10
Jun 4, 2004 04:36 PM
