Distributor Wiring
I have a B16 crx ijust went to put a new dizzy in and found one of tht plugs was cut off i need help
CRX SIDE Wiring
Blue/green
blue/yellow
orange/blue
orange
white
white
white/blue
DIZZY SIDE IT IS A TD-22U
blue/yellow
Lt. blue
orange/blue
orange
white/blue
white
yellow/green
i need to know what goes where
thanks
Modified by ESPTUNING at 11:25 AM 3/17/2005
CRX SIDE Wiring
Blue/green
blue/yellow
orange/blue
orange
white
white
white/blue
blue/yellow
Lt. blue
orange/blue
orange
white/blue
white
yellow/green
thanks
Prividing oem colors...
Look closer at the colors, they match, Solo (fat) white to Solo (fat) white
Modified by droppedcrxsi at 10:11 PM 3/17/2005
it makes a difference if your running obd0 or obd1. if your running obd0 then all the wires should match the color. if you cant see the colors..spray it with carb cleaner and wipe it clean. if your runnin obd1 then the colors on dont match on 2 sensors...
TD 22u is a obd0 I believe... So I told you for obd0. If you are obd1 you must follow the instructions in your obd0-1 ecu jumper, they are made differently.
Ryan
Ryan
Taken from this Helms manual... http://www.carenthusiast.com/c...t.pdf
SENSORS
Cylinder: Blu/Grn C1 & Blu/Yel C2
TDC: Orn/Blu C3 & Wht/Blu C4
Crank: Orn B10 & Wht B12
SENSORS
Iron_Forrix
19
Jun 19, 2008 03:58 PM
JDMlyfestyle
Oct 16, 2004 07:04 PM
