Ash Try Bulbs
From: hittin corners so hard you can taste my rims..
the last time i looked, its a super small bulb, i belive the bulb number is "74", and you can find them at local part stores. its pretty common, only draw back, you have to take apart the whole console.. you have to remove it... it'll be wired to the cig lighter also.. same circuit.
You can pull just the ash tray/lighter out, you dont have to pull the netire console. I know i just switched mine out to an ITR one. But my old one is missing the bulb and th ITR is burnt out.
I will have to check again as i did not see anything that small at the parts store the other day. But I will check again. Thanks!
kos99ngel
24
Jun 30, 2007 11:39 PM
GSR95DXHATCH92
Jul 19, 2005 01:06 PM
