LX in a 91 CRX HF
Old Mar 17, 2005 | 08:03 AM
1990hf's Avatar
Default LX in a 91 CRX HF
My friend got a 2000 civic LX auto. and gonna do a B18c swap. Well he was wondering if the LX motor will fit his 91 CRX HF and what do he need. His CRX is a 5spd.
Thanks.
Old Mar 17, 2005 | 08:37 AM
rob42386's Avatar
Default Re: LX in a 91 CRX HF (1990hf)
ya it will fit, i would use get a pm6 ecu and run the hf's wiring harness, and everything bolts up, but the hf has a black box with emmission controlls, i think there is a few things that dont get hooked up.
he would also need another intake manifold, i would get a crx si manifold since it will have the obd0 injectors, and everything will bolt up.
as for the 5 speed situation, he needs to remove the torque converter, and get a clutch, flywheel and pressurplate, and also a OBD0 si transmission since they are cable.
he could use the Hf's transmission but they are geared horribly, so take advantage of the 30+ hp increase, and get a si tranny.
Old Mar 17, 2005 | 08:46 AM
1990hf's Avatar
(obd0 SI intake manifold, clutch, flywheel, pressurplate, and also a OBD0 si transmission)
My freind said thanks alot.
Thanks.
slammedz6ef
Nov 24, 2008 05:23 PM
dannymcar
Feb 18, 2007 07:08 PM
classciv
Jan 4, 2007 03:08 PM
HFpower
Oct 31, 2006 12:40 AM
SiR Inspired ED7
10
Feb 25, 2006 05:44 PM
