should i get an si/ex fuel pressure regulator for crx manifold or aem adjustable one
Old Mar 17, 2005 | 06:35 AM
srv3fender's Avatar
Default should i get an si/ex fuel pressure regulator for crx manifold or aem adjustable one
ok so i think im not getting enough fuel to the injectors on my d16y8 ,cause its feels like its missing some power, and im thinking its because its an hf intake manfold or which ever one is multipoint fi. i read somewhere on a swap page to get a fuel pressure regulator from an 92-95 ex or si system and id really like to do that over buying one of those adjustable fpr's on ebay, cause im afraid of setting it too low or and the same place or way to high, and i dont want to destroy my gas milage, i dont know how fprs work but im thinkin the ex/si would be smart and cut itself down at the right times.
i would appreciate yalls opinion greatly
Old Mar 17, 2005 | 06:16 PM
srv3fender's Avatar
Default Re: should i get an si/ex fuel pressure regulator for crx manifold or aem adjustable one (srv3fender
anybody
Old Mar 17, 2005 | 07:15 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">im afraid of setting it too low or and the same place or way to high, and i dont want to destroy my gas milage</TD></TR></TABLE>
To avoid setting it too high or too low you should install a gage on the fuel filter and check pressure before swapping regulators. Install the new fpr and set it to the pressure you observed before the swap. Then go from there. Gas mileage won't change much if you bump up the pressure a couple psi.
You won't be disappointed with the aem fpr.
aeenox
36
Feb 14, 2008 02:19 PM
srv3fender
Mar 17, 2005 06:50 PM
luciffer
Dec 17, 2004 01:24 PM
YourHondaSucks
Jun 9, 2003 10:21 AM
ZC_Power
May 23, 2003 02:30 PM
