best SOHC motor?
Old Mar 17, 2005 | 06:18 AM
mawkiemarc's Avatar
Default best SOHC motor?
whats the best SOHC motor out worth building and in the future, boosting after motor is built? it can be VTEC or not im juss wondering bc i wanna be different than all those who have DOHC, even tho its better, i juss wanna be different.....
Old Mar 17, 2005 | 06:34 AM
Darren's Avatar
I think thats a matter of opinion and money. I personally like the Z6 and the A6. Decent little engines, lots of available parts, and can be made to put out a healthy amount of HP.
Old Mar 17, 2005 | 07:06 AM
EP3_05's Avatar
Default Re: best SOHC motor? (mawkiemarc)
Any of the 1.6L d series engines are good. d16z6 d16y8 d16a6
Old Mar 17, 2005 | 07:56 AM
CRseXy's Avatar
Default Re: best SOHC motor? (91civic)
I would say the JDM d15b Vtec.
Old Mar 17, 2005 | 08:15 AM
knockout's Avatar
Default Re: best SOHC motor? (pogiTSI)
IMO the d16y8 is the best SOHC motor, of course I only say that because it has the best tranny (if u buy a full swap)
Old Mar 17, 2005 | 08:30 AM
EP3_05's Avatar
Default Re: best SOHC motor? (knockout)
Problem is the d16y8 hydro trans does not swap into the ed chassis without heavy modification and fab work.
Old Mar 17, 2005 | 08:49 AM
crxgator's Avatar
i heard that the d16a6 has the best block because of the girdle...anyone want to confirm this?
Old Mar 17, 2005 | 09:00 AM
c.dub's Avatar
Default Re: best SOHC motor? (crxgator)
I've heard the A6 is the best block because it has the strongest rods. Don't quote me on that, but either way the A6 is awesome, just couple that with a Y8 head and you'll have lotsa fun!
Old Mar 17, 2005 | 09:02 AM
CRX_1.8T's Avatar
My vote goes for the D16Z6 out of the old Si's and EX's.
Old Mar 17, 2005 | 09:10 AM
4drEF's Avatar
Keyboard Humorist
In stock form? The Y8.
in stock form with boost or NoS - Z6 or A6.
In BUILT form... probably the Z6.
Old Mar 17, 2005 | 09:30 AM
90 Si Hatch's Avatar
Default Re: (4drEF)
i had a stock A8 in my Si hatch and i blown it up with a 55 shot, now i have a Y8 with the 55 shot on it and i LOVE IT!!!
Old Mar 17, 2005 | 09:41 AM
mawkiemarc's Avatar
so yall are sayin probably block wise, go with the A6 and head wise probably go with the Y8? thats cool.
but i personally like my D16A6, even tho its a single, ***** mad quick......
Old Mar 17, 2005 | 09:42 AM
mawkiemarc's Avatar
ok heres another question?????
if you were to boost, stock wise, what would you swap into your 90?........
and juss for future reference, what are the engine codes for the SOHC VTEC motors, isnt it just D15B i aint sure..?
Old Mar 17, 2005 | 10:48 AM
nuckingfuts's Avatar
Default Re: (mawkiemarc)
Old Mar 17, 2005 | 10:53 AM
EJ1 wilcox's Avatar
Default Re: (nuckingfuts)
I thought the A6 rods were more beefy than the z6?
If you are going to boost a stock engine, I would go with the strongest rods, the A6...
Plus, with an A6 you don't have to mess with wiring up VTEC or OBD1...
Old Mar 17, 2005 | 11:13 AM
onePOINTsix's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">I thought the A6 rods were more beefy than the z6?
Plus, with an A6 you don't have to mess with wiring up VTEC or OBD1...</TD></TR></TABLE>A6, Z6 and Y8 rods are the same thing, no difference between them except the last digit of the part number. i guess you could say that 88-89 A6s have the best girdle becasue the caps are cast iron and the top plate is aluminum. All the other 90+ A6, Z6 and Y8s have a solid 1 peice aluminum girdle. I think the best motor combo for a build and boosted D16 would be a A6 block and a ported Z6 head (not the Y8 becasue the chamber is small thus it raises the static compression ratio a bit more)
edit: forgot that the 1st gen ZCs have the thickest stock rods on the D16s but they are VERY hard to find
Old Mar 17, 2005 | 01:15 PM
CRXVTEC69's Avatar
Default Re: (onePOINTsix)
I would have to say the D15B VTEC is the BEST of all SOHC motors IMO.
Old Mar 17, 2005 | 01:59 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: (CRXVTEC69)
Boosted A6 gets my vote.
Good luck man.
Old Mar 17, 2005 | 02:38 PM
mike.'s Avatar
Default Re: (LankorDie)
i like my girls like my cars with d's not b's
Old Mar 17, 2005 | 02:45 PM
boosted_hatch_216's Avatar
how about a sohc zc. they have a more agressive cam and are the same as an a6.
Old Mar 17, 2005 | 02:51 PM
green91's Avatar
d16y8 is great if you enjoy spinning main bearings!
my vote is for the d16z6 or d15b vtec.
Old Mar 17, 2005 | 02:53 PM
EtaK's Avatar
For boost....low mileage y7 maybe y8 or a6 (w/ whatever mi.) ? Theres less other parts to buy if i go with the a6 right?
thx
Old Mar 17, 2005 | 03:26 PM
nota-ex's Avatar
Default Re: best SOHC motor? (Sepulcher)
I'm not 100% sure one this, just what I've heard. But I heard that the D series motors arn't great on boost with a stock bottom end because they have much weaker rods/pistons than most B series.
I'm not 100% sure of that, just one of the things I've heard on HT
Old Mar 17, 2005 | 03:44 PM
green91's Avatar
ive ran 12psi no problems on a z6... i keep 6psi on it daily
Old Mar 17, 2005 | 03:50 PM
nota-ex's Avatar
Default Re: (green91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">ive ran 12psi no problems on a z6... i keep 6psi on it daily</TD></TR></TABLE>
Stock internals?
