FLY WHEELS 11LBS
Old Jan 24, 2002 | 05:38 AM
SCsol's Avatar
Default FLY WHEELS 11LBS
hello there im gettting a JUN 11LBS flywheel. im putting it on my ITR motor . i know that it wil rev faster but what will it do to HP and TQ i heard that it will make less TQ but more HP please mail me with your thoughts and experiances with light FLYWHEELS thanks again
and also is there starter engagment problems with the JUN flywheels thanks
Old Jan 24, 2002 | 06:06 AM
BoM's Avatar
BoM
Default Re: FLY WHEELS 11LBS (lowsol)
dont' listen to what everyone says...the lighter the better, and u make power everywhere.
peep this out! https://honda-tech.com/zerothread?id=54704
if u have an integra you might have starter problems.
im getting a clutchmasters. If money is an issue try a Fidanza.
Old Jan 24, 2002 | 06:14 AM
SCsol's Avatar
Default Re: FLY WHEELS 11LBS (BoM)
thanks for the reply i didnt want to spend $400 on no gains and i take it the motor will rev better right
Old Jan 24, 2002 | 06:33 AM
John's Avatar
New User
you'll lose a bit low end (rotational inertia), but the car will rev better at high rpms... and shoot to redline in the blink of an eye when you rev with no load... i honestly didn't see too much in the way of a significant power gain with my Fidanza though...
Old Jan 24, 2002 | 08:15 AM
rainforest's Avatar
Default Re: FLY WHEELS 11LBS (DunReit)
yeah its parasitic drag its just like a lighter valve train it just frees power to the wheels instead of producing it.
Old Jan 24, 2002 | 08:36 AM
13secondcivic's Avatar
New User
Default Re: FLY WHEELS 11LBS (rainforest)
well....I run and sell only clutchmasters (same as Fidanza) and I use and sell the 8.5 lb flywheels. as for power....I noticed a big difference in my ZC, and even more when I added a turbo. the light flywheel WILL help with turbo applications more so than NA. especially in VTEC equipped cars, the light flywheel will hamper at times. torque may suffer a bit. in Turbo apps, the lighter flywheel will spool up quicker and stay up longer. this comes from CM.
Old Jan 24, 2002 | 08:39 AM
sgT's Avatar
sgT
if you havent bought that flywheel yet, get a fidanza. its lighter and right now
its on sale 300 shipped. much better than the JUN
Old Jan 24, 2002 | 08:43 AM
SCsol's Avatar
Default Re: FLY WHEELS 11LBS (sgT)
are fidanza. flywheels better then JUN please give me a little input for some reason i dont belive that it may be true please fill me in
Old Jan 24, 2002 | 08:52 AM
New User
as far as better.....hmmm....like I said, I use CM and have used them for years. they are the same as Fidanza! and CM is cheaper Fidanza makes CM from what I heard from CM The CM/Fidanza flywheels are billet, solid billet. the JUN flywheels are lightened....holes cut in them. the full pieces are usually a safer bet. the CM/Fidanza stuff is all SFI or whatever that goverment standard is...approved
Old Jan 24, 2002 | 09:56 AM
shivers's Avatar
He may have been referring to the fact that some people have had starter/flywheel grinding when using the JUN flywheel. There was an issue with the flywheel not matching up with the USDM starter. Not sure if this has been corrected.
Tony
Old Jan 24, 2002 | 02:41 PM
C1V1C's Avatar
Default Re: FLY WHEELS 11LBS (13secondcivic)
sorry:
"JUN flywheels are 200% stronger than stock flywheels. The JUN flywheel is made from a one piece forging using the special grade of steel known as chromoly. By forging a chromoly flywheel, JUN eliminated unnecessary weight making the turning inertia smaller."
Old Jan 24, 2002 | 07:06 PM
Kamin's Avatar
Default Re: FLY WHEELS 11LBS (C1V1C)
hey
you have an itr? the itr flywheel is like 12 lb right? why bother with an 11 lb one, go all out with an 8 or 9 lb one i have a 8lb clutchnet in my b16. screams like a bitch. but you do loose a little torque down low. talk to ben@importparts. was around 300~ for mine.
Old Jan 24, 2002 | 07:11 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: FLY WHEELS 11LBS (KAMiN)
I'm using a 7.5lb fly, and love it. CM, Fidanza, same thing.
Old Jan 24, 2002 | 08:32 PM
Dirty GS-R's Avatar
New User
hey
Actually the stock ITR flywheel is about 16lbs if I'm not mistaken.
Old Jan 24, 2002 | 08:37 PM
Kamin's Avatar
Default Re: FLY WHEELS 11LBS (2K1 GS-R)
hey
really? i thought stock b series flywheels were 16 or 18 and the itr was less
i could be wrong.
Old Jan 25, 2002 | 06:30 AM
Dirty GS-R's Avatar
New User
i could be wrong.
The stock ITR flywheel is ~2lbs lighter than all other integras. My stock GSR flywheel was ~18lbs.
dstappity
Jan 19, 2011 06:33 AM
thegatekeeper14
11
Aug 20, 2006 03:44 PM
danny98r
Jul 12, 2004 11:07 AM
H_doubledeuce_A1
Jan 21, 2004 05:46 PM
dominate9
Jun 17, 2003 03:14 PM
