Bench Bleeding
Ok so i need some help.... I need to bench bleed my clutch master cylinder, and i don't really get the whole "bench bleeding" process.... if anyone can help, id appreciate it....
Get a hose or tube that fits in where the clutch hydraulic line goes. Loop it up into the reservoir.
Put brake fluid in, pump the piston a bunch of times. This pumps fluid thru the hose back into the reservoir. If you work the air bubbles out of the MC this way, it's easier to bleed after you install it in the car.
Johnmadsen
Apr 15, 2018 03:16 PM
