omnipower camber kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrota »</TD></TR><TR><TD CLASS="quote">i need opinions on omni power front camber arms and the shim kit on the rear. Is this set up good enough to fix camber? </TD></TR></TABLE>
what's wrong with your camber that needs fixing?
im getting the camber kit b/c i want a 2.25" drop, but not sure how much adjustment is needed.
also, i've been reading the posts and it seems like camber is okay up to -2.5..so does anyone know whether a 2.25" drop on an ek would result in more than -2.5 camber? if not then i guess i can just get an allignment to make sure toe is corrected.
Modified by jdmrota at 2:01 AM 3/18/2005
I've been happy with the omnipower kit on the front. I just replaced the puny ball joint boots with some oem honda boots and replaced the little spring that held the boot with an oem clip.
I just got some washers for the rear, but the omnipower kit should be fine.
wat would happen if i keep the boots and the puny springs that hold them together instead of swaaping for oem parts like u did? is the origina set up is not as good? thanx
