O2 Sensor Cleaning
Old Mar 16, 2005 | 10:50 PM
gamakichi77's Avatar
Default O2 Sensor Cleaning
How can i clean my O2 sensor.......i thinks rite it is full with carbons.....
Old Mar 17, 2005 | 06:24 AM
Jmunk's Avatar
This goes back to the old saying "if it isn't broke don't touch it". Carbon on it? What do you think happens when you put something in the exhaust stream ?
Old Mar 17, 2005 | 04:13 PM
Default Re: (Jmunk)
rite now my air/fuel ratio meter not working as usual....not so stable......crazy.
is it cause of O2 sensor malfunctions?
Old Mar 18, 2005 | 05:12 AM
wdwalker's Avatar
Default Re: (acidburns_di)
if you're talking about how it fluctuates back and forth on idle and partial throttle, then the answer is no. the reason it fluctuates back and forth is because of your ecu being in closed loop mode. at more than about 65% throttle, it should make up its mind about which led to light up. or just use hondata or uberdata to disable closed loop altogether, it won't fluctuate at all with CL disabled.
bigmikey7351
Jun 3, 2008 09:01 PM
youngvedder
Oct 24, 2004 12:42 PM
ChaosUnbound
Aug 25, 2004 08:12 AM
gitwidit
Mar 10, 2003 10:36 AM
