High mileage ITRs
Old Jan 24, 2002 | 04:01 AM
evergruven's Avatar
Default High mileage ITRs
Anything historically wrong with a high mileage ITR? Would there be anything wrong with starting to build up a fomerly-stock 85K mile ITR engine up? What's maintainence like at such relatively-high mileage? Any other info/comments are appreciated. Thanks.
Old Jan 24, 2002 | 04:19 AM
ZygSpeed's Avatar
Default Re: High mileage ITRs (evergruven)
I've just turned 100K miles in my 97 R.
My first and only compression check netted numbers in the 225-210 range just days ago, so there's no inherent reason not to get the car.
I guess a compression and leakdown check (on a warm engine), after a valve adjustment, would be a good indicator of the state of health. I'd change the timing belt ASAP if it hasn't beeb done already.
Sounds good, buy it and have some fun!
Old Jan 24, 2002 | 06:47 AM
BudMan's Avatar
Default Re: High mileage ITRs (zygspeed)
ditto Ed - I'm at 79,000 miles on my '98 & just finished timing belt, water pump, tensioner pulley + replaced original clutch/pressure plate/flywheel last couple weeks ....
Don't skimp - just keep up good maintenance & if you driver her hard do maintenance a bit earlier then recommended. You'll be fine!
mikeintegra93
Dec 30, 2008 01:43 PM
kuklovod
Jul 7, 2006 10:53 PM
Biloxi
Feb 4, 2005 10:24 AM
siciliani
May 7, 2003 09:44 AM
B18EG6
Dec 9, 2002 05:19 PM
