what does it take to run 12's in a ef?
Old Mar 16, 2005 | 09:23 PM
ceLtic's Avatar
N/A wh0re!
Default what does it take to run 12's in a ef?
i have a crx and im building a motor...
https://honda-tech.com/zerothread?id=1084752
thats my ls/vtec thread in the ALLMotor forum...im hoping for 200whp, and if any of you have had 200whp...what did you guys run in the 1/4 with a full weight crx?
what did you have [as far as whp/setup] to run your 12 second e.t. in your ef?
and did anyone run a 12second e.t. with less then 200whp here?
thanks guys...just looking to get a basic idea of what to expect with my build for my crx.
Old Mar 16, 2005 | 09:53 PM
Burlyirishdude's Avatar
Default Re: what does it take to run 12's in a ef? (ceLtic)
dude your % is down to 1! how is that even possible.....
Anyway...you could do it...your motor could get you there deffinately...just put your crx on a diet... get an Hf!....
Old Mar 17, 2005 | 11:14 AM
ceLtic's Avatar
N/A wh0re!
Default Re: what does it take to run 12's in a ef? (Burlyirishdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">dude your % is down to 1! how is that even possible.....
Anyway...you could do it...your motor could get you there deffinately...just put your crx on a diet... get an Hf!.... </TD></TR></TABLE>
what i did was go 166mph and made a video of it, and posted here...anyway...
im taking off the bumper supports and any other unnecessary interior
anyone else?
Old Mar 17, 2005 | 11:19 AM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">what i did was go 166mph and made a video of it, and posted here...anyway...</TD></TR></TABLE>
<FONT SIZE="2"><FONT COLOR="red">OMG</FONT></FONT>
For the brass ***** to try that
Getting deductions for it
Old Mar 17, 2005 | 11:25 AM
onePOINTsix's Avatar
Default Re: what does it take to run 12's in a ef? (GreenBean)
nice video anyway with the right tune you could get it above 200whp. My good friend has a built B18C5 with CTR pistons, DART P&P B16 head, Crane Stage2 cams, Extrude honed and angle milled ITR intake manifold, JUN header to a Hytech exhaust and a AEM 3in with a veloicty stack and 6in K&N. It put down a little over 200whp on a Dynapak with a great tune (thanks to Dan at Godspeed )
Old Mar 17, 2005 | 11:34 AM
kulangot's Avatar
anyone else?</TD></TR></TABLE>
that sucks.......btw hope you hit 12's....
Old Mar 17, 2005 | 12:00 PM
JsEFx's Avatar
k20a
Old Mar 17, 2005 | 12:08 PM
abnaasefmb's Avatar
Default Re: what does it take to run 12's in a ef? (sirq2u)
i have a b16 @145whp + 50 shot. si hb full int. ac best run was 14.00@ 102.5 i should have hit 13's but the clutch was slipping. like it was stated above you should be able to pull more than 200 with your set up, strip out what you can, use a good clutch and slicks and you should be on your way. its hard to put a time with a car with a set amount of hp because drivetrain and driver come into play. but i can see you going 12's at about mumm say 166 mph. good luck!
Old Mar 17, 2005 | 12:12 PM
HatchBox's Avatar
Skoobie no more...
I think the h22 swap in our chasis will run a high 12
warpigtype-s
Feb 2, 2009 05:50 AM
k20zno2
Aug 6, 2007 11:20 AM
Black R
Jan 10, 2003 02:03 PM
balistic CRX
10
Feb 20, 2002 02:56 PM
