LSVTEC questions
Old Mar 16, 2005 | 08:20 PM
Mushvroom's Avatar
Default LSVTEC questions
No No No, it ain't no "Is lsvtec reliable" or "What do I need for lsvtec" type of questions.
But, is there anything wrong in buying USED ITR pistons, ITR valve springs & retainers, and CTR cams?
Also, how much do those go for used/new? Any info would be great. Thanx.
Old Mar 16, 2005 | 08:27 PM
LSTEG96's Avatar
Default Re: LSVTEC questions (Mushvroom)
dont go itr pistons... u have to shave the rods...boo that. everything else, yes.
you'll also want the vtec water and oil pumps. and all that jazz.
Old Mar 16, 2005 | 08:32 PM
Mushvroom's Avatar
Default Re: LSVTEC questions (LSTEG96)
Yeah, I know what I need , I think. But is it ok to get them used? If not ITR pistons, then what pistons?
Old Mar 16, 2005 | 08:50 PM
MenaceL.A.671's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mushvroom &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I know what I need , I think. But is it ok to get them used? If not ITR pistons, then what pistons?</TD></TR></TABLE>
ITR pistons are good.. just have to shave the small end of the rods... i have JDM ITR pistons on mine ls/vtec and havnt had a problem with it.. *knocks on wood* and i rev up to 8200 with ARP rod bolts.. but i have aftermarket springs retainers etc on the head...
LSTEG96's Avatar
pr3!!
Old Mar 16, 2005 | 08:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">pr3!!</TD></TR></TABLE>
solid
or CTR pistons.. high ****** compression...
Old Mar 16, 2005 | 09:39 PM
LSTEG96's Avatar
Default Re: LSVTEC questions (m2slsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m2slsvtec &raquo;</TD></TR><TR><TD CLASS="quote">solid
or CTR pistons.. high ****** compression... </TD></TR></TABLE>
yeah CTRs are sweet too, but pump gas becomes questionable. on a gsr head with the ctrs your c/r is 12.4:1 thats pretty high for even 93 octane.
i had my lsvtec spinning to 9200 trying to blow it up... it woudlnt happen.
Old Mar 16, 2005 | 09:42 PM
SYTFU Tommy.'s Avatar
the highest i ever seen a ls-vtec rev was past 9k. wasnt sure wat it was actully, was using the stock cluster, it was stuck after the 9k mark where we made a mark.
Old Mar 16, 2005 | 09:47 PM
LSTEG96's Avatar
Default Re: LSVTEC questions (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">the highest i ever seen a ls-vtec rev was past 9k. wasnt sure wat it was actully, was using the stock cluster, it was stuck after the 9k mark where we made a mark. </TD></TR></TABLE>
...i just had an ls cluster..the stock one. redline at 7, tach ends at 8.5k, then u just burry it.
Old Mar 16, 2005 | 09:51 PM
it was on a eg. with a si cluster i believe. the max it goes was 8k. we getto rigged it with like a red tape to show where 9k would be by like measuring the distance from every 1k rpm.
Old Mar 16, 2005 | 10:03 PM
Mushvroom's Avatar
So ITR pistons are good..but just needs to be shaved. What is PR3 again?
And I am completely building a ls/vtec, from bottem end to changing the valve cover..all good stuff, so I can drive this monster for awhile.
Old Mar 16, 2005 | 11:15 PM
LSTEG96's Avatar
Default Re: (Mushvroom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mushvroom &raquo;</TD></TR><TR><TD CLASS="quote">So ITR pistons are good..but just needs to be shaved. What is PR3 again?
And I am completely building a ls/vtec, from bottem end to changing the valve cover..all good stuff, so I can drive this monster for awhile.</TD></TR></TABLE>
um, yes, itr are good. pr3 are b16a pistons. Valve cover?? why are u changing the valve cover?
Old Mar 16, 2005 | 11:29 PM
Mushvroom's Avatar
Just wanted to let ya'll know that I am completely building this up, from the block all the way up to the head...but I do like the red valve covers over the ls's.
So do I need a shop to have the ITR pistons "shaved"? And should I use better rods or just my stock B16B rods?
Old Mar 17, 2005 | 09:48 AM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mushvroom &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to let ya'll know that I am completely building this up, from the block all the way up to the head...but I do like the red valve covers over the ls's.
So do I need a shop to have the ITR pistons "shaved"? And should I use better rods or just my stock B16B rods?</TD></TR></TABLE>
wait... dood. the rods must be shaved, not the pistons, u had better not have b18b rods in that ls motor, and red valve cover over the ls? dont u mean over the vtec head? a red valve cover on an ls head is not an lsvtec
Old Mar 18, 2005 | 07:31 AM
Mushvroom's Avatar
Default Re: (LSTEG96)
So rod have to be shaved. OK. Yeah, on the vtec head, mah bad, getting ahead of myself. Thanx,
Old Mar 18, 2005 | 07:44 AM
Circuit Star-29's Avatar
If you use p30 pistons then you'll get a good compression and you wont have to shave the rod. If you have questions that our website can answer please feel free to visit...they're in the how-to section. http://www.c-speedracing.com
Old May 19, 2005 | 09:40 AM
drunknmonkey18's Avatar
Default Re: (C-speed Racing)
can i use arp rods w/ pr3 or p30 pistons?
itr1244
15
Mar 29, 2009 05:46 PM
mac_24_seven
11
Aug 7, 2007 02:31 PM
ekVtecPower
Jun 22, 2006 09:08 PM
dc2gsr96
65
May 26, 2006 01:52 PM
