Zc Injectors???,
Old Mar 16, 2005 | 08:08 PM
JDMb16ef's Avatar
Default Zc Injectors???,
hello there, i want to replace my injectors, but i am not sure from what car shoud i get them.
A friend of mine told me that i could use the 88-89 integra, or the prelude ones, but i am not sure from what year can i use the prelude injectors.
Iwant something bigger than the once that i have, since i am using the 89 ECU integra. so let me know
Anything is going to help me,
Thank you
Old Mar 16, 2005 | 09:06 PM
EP3_05's Avatar
Default Re: Zc Injectors???, (JDMb16ef)
IMO there is no need to go any larger unless you are running a turbo, nitrous, or very high compression. 240cc are stock on the integra type-r as well as most other hondas except a couple of preludes so the zc is 130hp while the itr is 195 so you do the math.
Old Mar 16, 2005 | 09:11 PM
kulangot's Avatar
Default Re: Zc Injectors???, (91civic)
any non-obd will work...but do not use ant hf injectors..
Old Mar 17, 2005 | 01:09 AM
Nerologic's Avatar
Default Re: Zc Injectors???, (sirq2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u &raquo;</TD></TR><TR><TD CLASS="quote">any non-obd will work...but do not use ant hf injectors..</TD></TR></TABLE>
you CAN use HF injectors
the HF injectors are the same as SI,B16,ZC and all the other peak and hold injectors MINUS the prelude and NSX ones
but either way, stick with stock
sporkcrx
Oct 21, 2006 01:07 PM
gutted-dx
14
May 23, 2005 04:39 PM
junkyardRx
Sep 6, 2004 04:02 AM
rextec
Oct 10, 2003 05:08 AM
ZColeon
Nov 7, 2001 09:06 AM
