anybody knows why my integra clutch pedal sticks down?
Old Mar 16, 2005 | 08:05 PM
beefjerky's Avatar
Default anybody knows why my integra clutch pedal sticks down?
i mean everytime i push it down to shift gear it always stick down and doesnt want to come up...id then have to puch it one more time for it to pop back up....i mean its such a hassel
Modified by beefjerky at 9:18 PM 3/16/2005
Old Mar 16, 2005 | 08:09 PM
SuzukaBlueAP2's Avatar
Default Re: anybody knows why my integra clutch pedal sticks down? (beefjerky)
what year integra? low clutch fluid? bad slave cylinder?
Old Mar 16, 2005 | 08:17 PM
beefjerky's Avatar
Default Re: anybody knows why my integra clutch pedal sticks down? (ScreaminTeg)
Da model
Old Mar 16, 2005 | 09:22 PM
AllmotorJunkie's Avatar
Sounds like your slave cylinder is going bad. Might want to get a second opinion!
Old Mar 16, 2005 | 09:25 PM
M-EJ1's Avatar
DA's have a cable clutch... sounds like you need to lube the cable.
I don't know how to do it, mine seems to work well, but I'm sure if you search on the g2ic.com forums you will find a writeup.
rufridn's Avatar
^^thats most likely it. check your fluid level [the one by the brake fluid reservoir].
Old Mar 16, 2005 | 09:33 PM
EF-EF's Avatar
um DA's are cable not hydro so no fluid...I would just replace the cable if I were you...
Old Mar 16, 2005 | 09:37 PM
carnifex's Avatar
Default Re: (EF-EF)
pray it is the cable and not the clutch itself. it sounds to me like a boroken spring in the clutch plate itself. i have seen this on toyotas and kawasaki motorcycles.
Old Mar 17, 2005 | 12:11 AM
JunTec's Avatar
Default Re: (carnifex)
That happend to me when i partly broke ma clutch cable...Then it eventually snaped...
Check the cable down by the tranny...It could be just loose...
Old Mar 17, 2005 | 12:49 PM
beefjerky's Avatar
Default Re: (JunTec)
ok thanks for you guys help..really appreciate it..
Kannan08
Transmission & Drivetrain
Oct 23, 2011 11:17 PM
4drDA
Aug 29, 2005 01:11 PM
Mush-
12
Jul 4, 2003 03:10 PM
LSBeast
Apr 16, 2002 08:18 AM
