Fast wear with the Kumho Ecsta 712?
I am around 25k miles on my last set of tires that I bought, KUMHO ESCTA 712, which replaced my stock michellins. I notice that Kumhos almost need replacing....I can probably scew out another 5-6k miles. Is this normal for the Kumho Escta????? The tread rating on these are 340! While the stock Michelins were only 220. However, I got 50k miles on my stock Michellins. I rotate my tires every 6-7k miles and DO NOT drive like a mad man. Most of the miles are daily freeway commuting miles.
Anyway, any experiencing the same problem with fast tread wear on the Kumho Estca??????? After this set is gone, I will look into another brand....something that will last a little longer
they are soft tires, I wouldn't recommend them for a car used as a daily driver. I usually see good wear out of the cheap yokohama model with 420 tread wear.
