LS vtec cooling question
I am planning of doing a LSvtec into my 90 integra,my question is,about my radiator,will the stock LS be enough or should I upgrade to an aftermarket? And does anyone have any articales on LSvtec so I can read more about it,thanks.
hey if you are lucky enough to find a 92 gsr oil cooler will also help you
but thats the least of your worries unless you mill down the head so low
that you are not able to get the timming right..
if you do you will most defetnly need to adjust timming right of the distributor
and some adjustable cams also.......
