JDM B16 s1/jdm xsi B16 s1... differences?
Old Mar 16, 2005 | 06:07 PM
slambedcivic's Avatar
Default JDM B16 s1/jdm xsi B16 s1... differences?
a friend of mine just purchased a JDM XSI transmission off of ebay. its labeled S1. HE also has as JDM B16 transmission that came with the swap from a local place we have dealt with. it too is labeled S1. are there any differences between the 2 of the trannys? please let me know and thanks in advance for any provided information...
yes, i did search...
Old Mar 16, 2005 | 06:52 PM
MadVTEC's Avatar
Default Re: JDM B16 s1/jdm xsi B16 s1... differences? (slambedcivic)
Try google next time.
searched: B-series transmission
Best result: http://www.allmotorhonda.com/t...s.htm
Old Mar 16, 2005 | 07:33 PM
Malgerus's Avatar
Default Re: JDM B16 s1/jdm xsi B16 s1... differences? (MadVTEC)
There is 1 JDM S1. They are the same thing. They have the same gearing as the JDM J1.
Old Mar 16, 2005 | 07:37 PM
CUSTOMCONNECTION's Avatar
Old Mar 16, 2005 | 09:09 PM
Default Re: JDM B16 s1/jdm xsi B16 s1... differences? (CUSTOMCONNECTION)
so this friend of mine got ripped off basically when he bought his b16? they sent a S1.... i guess this is wrong?
Old Mar 17, 2005 | 08:01 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">so this friend of mine got ripped off basically when he bought his b16? they sent a S1.... i guess this is wrong?</TD></TR></TABLE>
What?
We're telling you that they're the same transmission. Unless that importer threw in a 90-90 USDM Integra S1 transmission and called it a JDM one.
Old Mar 17, 2005 | 08:26 AM
Default Re: JDM B16 s1/jdm xsi B16 s1... differences? (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
What?
We're telling you that they're the same transmission. Unless that importer threw in a 90-90 USDM Integra S1 transmission and called it a JDM one.</TD></TR></TABLE>
no, the B16 swap came with the S1... is it possible that he just got the XSi motor with the S1 tranny?
Old Mar 17, 2005 | 09:00 AM
SiZ's Avatar
SiZ
Yes, its possible.
There's no difference between them.
Old Mar 17, 2005 | 09:04 AM
ricodemus's Avatar
no, the B16 swap came with the S1... is it possible that he just got the XSi motor with the S1 tranny?</TD></TR></TABLE>
XSi motor is a b16, is it not? You don't make any damn sense.
Old Mar 17, 2005 | 10:12 AM
Malgerus's Avatar
Default Re: JDM B16 s1/jdm xsi B16 s1... differences? (ricodemus)
Exactly. The S1 is a JDM Integra XSi Transmission, and it was used for the B16A (Man this thread is unneccessarily complicated) I'm not 100 percent sure what you're getting at, but if you look at the serial number below the B16A stamp you'll be able to tell if it's an SiR motor or an Xsi motor... a number starting with 5xxxxx is a JDM CRX SiR engine, and a number starting with 1xxxx is an Integra B16. It's possible that your importer mated a JDM S1 with a CRX SiR motor which would have come with the Y1 tranny - which sometimes had LSD. The YS1 tranny is also an Integra transmission, but it came on the 92-93 Xsi... it has a larger mainshaft and bearings, and sometimes comes with LSD. I hope this clears everything up for you. Basically if you put in that S1 and it has long gears, you got screwed with a USDM S1 transmission. If it's the short geared one, it's exactly the same as your other S1.
Old Mar 17, 2005 | 01:35 PM
okay...
my best friend got what was supposed to be a SiR swap..... but it came with a S1 tranny therefore he paid for the SiR swap, but got hte XSi swap. i wont know for sure unless i check the serial numbers on the block. so well see...
sorry about all of the confusion!
Old Mar 17, 2005 | 01:58 PM
greatwhiteshark's Avatar
Tell you what, sell me the S1 and that'll sort all your problems. I've been after one for ages.
Old Mar 17, 2005 | 02:06 PM
Default Re: (greatwhiteshark)
one needs to be rebuilt, and the other will be in use...
Old Mar 17, 2005 | 11:09 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">okay...
sorry about all of the confusion!</TD></TR></TABLE>
That's cool man.
Your friend didn't necessarily get ripped off. I have a 5xxx series b16a and it's great, but odds are the Integra ones are a little less ragged on. That and the Y1 tranny has taller gearing.
Old Mar 18, 2005 | 02:55 AM
EFOSV's Avatar
i got the jdm S1 and i love it , short gears rule ...
Old Mar 18, 2005 | 03:02 AM
PaImportTuner's Avatar
Default Re: (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">one needs to be rebuilt, and the other will be in use...</TD></TR></TABLE>
where did he get the swap from? hopefully not local from maryland.
XSi with JDM S1.
i rather have XSi swap. it had 10 more ponies than the SiR, pr3 ecu and higher lift(.4mm) on intake and exhaust lobes, c/r is 10.4:1 unlike SiR 10.2:1.
these importers just put together **** that works. if everyone wanted just a full xsi or SiR alot of people would have broken trans and engines. so you'll have mix matched stuff.
Modified by PaImportTuner at 7:31 AM 3/18/2005
Old Mar 18, 2005 | 03:08 AM
Default Re: (EFOSV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFOSV &raquo;</TD></TR><TR><TD CLASS="quote">i got the jdm S1 and i love it , short gears rule ... </TD></TR></TABLE>
daily driving consist of 1st 3rd 5th when full stopped or 2nd 4th 5th when i slow down and downshift and light turns green i dont think about it i just do it.
Old Mar 18, 2005 | 08:18 AM
Default Re: (PaImportTuner)
thanks everyone!!
Old Mar 28, 2005 | 12:53 AM
Still interested in the gearbox if you want to sell it.
Old Mar 28, 2005 | 03:18 AM
its still not out of the car
Old Sep 19, 2005 | 10:06 PM
redDA90's Avatar
how much do you think that an S1 trans is worth???
Old Sep 21, 2005 | 08:17 AM
FakeJDMEF8's Avatar
i have a JDM S1....grinds in 3rd a little bit...how much is it worth? the barcode is completely visable and otherwise good condition.
Old Oct 11, 2005 | 03:48 AM
Xsi's Avatar
Xsi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">where did he get the swap from? hopefully not local from maryland.
XSi with JDM S1.
Modified by PaImportTuner at 7:31 AM 3/18/2005</TD></TR></TABLE>
Only the 1991~93 XSi's had the extra 10hp, 89~91 had the exact same engine as the old shape SiR.
umair
Feb 5, 2011 02:52 PM
JakeSpec
Aug 7, 2008 09:08 AM
eg510
Feb 22, 2006 09:23 PM
BoostinEJ1
Aug 29, 2005 05:35 PM
