Pistons help!
Old Mar 16, 2005 | 05:29 PM
HondaIntegraR's Avatar
Default Pistons help!
Sup guys i need some pistons for my all motor setup... originally was gonna go wiseco ib spec 85.5 @ 12.1 cr............. they had those in stocks... but i recently gain some advice and now plan on going to a cr of 11.1 pistons... i have some flat top valves which will bump compression to something less than 11.5... anyways i dont' think many people have these in stocks or if you do ... pm me... but yeah looks like i have to have my pistons custom made. Any suggestion on a company that make pistons relatively quick?
thanks for your help!
going in here
Old Mar 16, 2005 | 10:35 PM
Default Re: Pistons help! (HondaIntegraR)
bump
Old Mar 17, 2005 | 09:09 AM
bump before my final!
Old Mar 17, 2005 | 11:19 AM
asubennett's Avatar
I am biased towards CP. But Weisco and JE are both greaat pistons as well.
Check out IB or Edyyn they both sell nice versions of Weisco's
Old Mar 17, 2005 | 10:22 PM
Default Re: Pistons help! (asubennett)
might have to go w/ CP, IB don't have the compressioni want, and i here too much bad stuff about endyn
Old Mar 18, 2005 | 06:27 AM
NJIN BUILDR's Avatar
CP and JE are typically about two weeks.This is about the busiest time of year and they might be out to 3 weeks now.You need to decide your compression ratio first.A word of advice on cr.Your better being a little low than too high.You will lose more power retarding the timing to keep it from detonating than you will from being a touch to little cr.
Glenn
Old Mar 18, 2005 | 12:13 PM
Default Re: Pistons help! (NJIN BUILDR)
IB hast 12.1 in stock, i know thats high for pump gas, especially since i have a gsr head plus flat top valves, but is it possible to decrease compression by a point if i had the chambers in my head opened up?
Old Mar 18, 2005 | 01:02 PM
Opening the chambers up will help a little.You may be able to have the dome machined down a little too.Have everything measured,you may be closer to 11.5:1 than 12.1:1.
Glenn
Br1anPham
Nov 16, 2021 06:50 AM
be18see1
Feb 16, 2009 12:00 PM
DJ_NeX
Oct 9, 2008 03:10 PM
no_sir
Mar 17, 2008 11:51 PM
built4cubanlynxx
Mar 6, 2005 03:06 PM
