Driving at night - headlights go out - not normal
Old Mar 16, 2005 | 05:24 PM
SiRLudeVtec's Avatar
Default Driving at night - headlights go out - not normal
Lately, my headlights have been going out every once in a while. I definately know its an eletrical problem of some sort. They're on for a while, but sometimes, they just cut out - i have to play around with the switch to get it to come back on - and i have to step on the gas - maybe i have a pinched wire or something...any suggestions.
Old Mar 16, 2005 | 05:38 PM
AndyD's Avatar
Default Re: Driving at night - headlights go out - not normal (AJBurks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJBurks &raquo;</TD></TR><TR><TD CLASS="quote"> i have to play around with the switch to get it to come back on </TD></TR></TABLE>
Let me guess, you have a 5th Gen, right? I have heard of this issue before. It is the headlight switch on the steering column.
Old Mar 16, 2005 | 05:41 PM
OEM_ASSASSIN's Avatar
Default Re: Driving at night - headlights go out - not normal (AndyD)
mine did this in my JDM headlights inside of the H4 harness. The wire was arced I think. It melted a little
Old Mar 16, 2005 | 05:53 PM
I have a fourth gen with JDM h22 swap
Old Mar 16, 2005 | 06:47 PM
Boost3d22's Avatar
check you switch connection make sure its secure, then check ground wires!
Old Mar 16, 2005 | 06:48 PM
Boost3d22's Avatar
if this fails unbolt your head lights, go to homedepot, get 2 flood light/flashlights, ductape them to your frame turn them on, and your good to go!
Old Mar 17, 2005 | 08:04 AM
Default Re: Driving at night - headlights go out - not normal (Boost3d22)
Naw...I have some projectors at home - so i'll just get those installed after I check my switch and grounds
Old Mar 17, 2005 | 09:52 AM
94vtecmn's Avatar
Bottom line: Headlight Relay.
I had the same problem a few years back, tried all the suggestions above, it was the headlight relay. Honda could not determine that was it, because it was an intermitent problem, and didn't fail while they checked it. Stop spending time and money on anything else. I wish someone had told me this, because I would have saved the cost of a new switch, a Honda test, and a shitload of my time.
Old Mar 17, 2005 | 10:35 AM
Greyout's Avatar
Default Re: Driving at night - headlights go out - not normal (94vtecmn)
So if your headlights go OUT at NIGHT, the problem can be fixed by STEPPING ON THE GAS.
LOL sounds easy enough....
Old Mar 17, 2005 | 12:50 PM
Default Re: Driving at night - headlights go out - not normal (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">So if your headlights go OUT at NIGHT, the problem can be fixed by STEPPING ON THE GAS.
LOL sounds easy enough....</TD></TR></TABLE>
Nope not at all - when i step on the gas, the lights don't automatically come back on - like i said before, i have to play around with the switch in sync with stepping on the gas a bit. It doesn't happen often, but every blue moon it does...
barryst
Oct 20, 2009 03:17 AM
Frost7177
Jan 8, 2008 01:52 PM
dumkopf
Jul 31, 2007 05:13 AM
5G_Vtec
Mar 14, 2007 07:40 AM
Prelude SIR-T
Apr 18, 2006 07:29 PM
