distributor question
Old Mar 16, 2005 | 04:45 PM
brusk13's Avatar
Default distributor question
Ok got a 90 CRX DX. Getting ready to swap in a D16Y8 soon. Wanted to swap to the multi point FI first to ensure thats done with no problem so I'm not trouble shooting dumb **** if theres a problem in the swap. The dual point FI doesn't use a Cylinder Sensor like aparently all the multi points do. So I wired up a conversion harness so I could test out the Y8 distributor. The car ran but would only rev to 3500RPM's and I got a CEL code 4 which is the crank sensor. I checked and rechecked the wiring and it's correct. Is there something not compatible on a Y8 distributor. Next step was to wire up the rest and using a obd0 to obd1 harness use my Z6 ecu. Any help on this would be great.
Old Mar 16, 2005 | 05:08 PM
Magick211's Avatar
Default Re: distributor question (brusk13)
where you using a obd0 ecu with the y8 dizzy? if so thats your problem
Old Mar 17, 2005 | 08:30 PM
brusk13's Avatar
Default Re: distributor question (Magick211)
I kinda wondered that but at the same time can't see why it wouldn't. I figured a crank sensor is a crank sensor. ok next question then I'll be using a D16z6 ECU when i do the swap will the the Y8 distributor work with that ecu? And if you know what distributors will work with the SI ecu.
Old Mar 18, 2005 | 12:17 PM
p3lon21's Avatar
is the distribuator a white plug
Old Mar 18, 2005 | 01:18 PM
brusk13's Avatar
Default Re: distributor question (pelon 1990 civic si)
the Y8 distributor I have is a 8 pin gray plug.
Old Mar 27, 2005 | 05:46 PM
p3lon21's Avatar
get a obdo Si distribuator
Old Mar 27, 2005 | 07:04 PM
NikoZai's Avatar
So if you're going with a P28 ECU, OBD1, you want a OBD1 or OBD2 distributor (no you cant use an OBD0)
Dont test anything individually, you should do the COMPLETE swap all at once.
If you want your MPFI swap done right, get a Rywire conversion done to your DX harness.
backwoodslife94
Nov 13, 2016 12:20 PM
89b20crx
Jul 11, 2013 09:43 AM
Randysi
49
Oct 30, 2011 09:54 PM
CRX_Control
Aug 4, 2004 03:20 PM
