11.4@126, can the time be improved?
Old Mar 16, 2005 | 04:24 PM
Flexmyrex's Avatar
Default 11.4@126, can the time be improved?
92 hatch cx bone stock gsr 400hp on 22-8-15 slicks. The car ran consistent mid to high 11's, best run was 11.4 @ 126. Do you think the 1/4 times can be lowered with 24x8x15 or 13's, and high rate springs for the rear (lbs??1000? car is street but can tolerate high rates). Any other adjustments or comments welcome, just trying to see if the car could go deeper into 11's @ same hp level with some adjustments.
if the pic doesnt work:
60' 1.748
330 4.944
1/8 7.507
MPH 96.81
1000 9.673
1/4 11.449
MPH 126.96
Old Mar 16, 2005 | 06:30 PM
Killer_B's Avatar
Default Re: 11.4@126, can the time be improved? (Flexmyrex)
must have been some great driving because i yielded a crappier time with a slightly higher mph on a 24.5x8x13.
good luck and great driving
Old Mar 16, 2005 | 09:21 PM
turtle-eg's Avatar
No help here... but you are keeping my hopes of running better times alive... I also have 400whp but my best time at the track so far is 11.85 with a 1.9 60ft. I'm running on 24.5x8.5x13 M&H if that's any help....
Old Mar 16, 2005 | 11:17 PM
svpAMhatch's Avatar
22x8x15 that means u were u mt's right? 23x8x13 m@h should be cool. lower your 330' to a 4.7 that would to cool. goodluck
Old Mar 17, 2005 | 05:13 AM
Tyler H's Avatar
I've gone 11.0 @ 126 with about 400 hp beofre. That was on 24.5" M&H's. You have the hp and mph to run a little quicker than your 11.4.
Tyler
Old Mar 17, 2005 | 05:22 AM
Evil DOHC's Avatar
Default Re: 11.4@126, can the time be improved? (Tyler H)
I have ran 11.4 @ 120 in a 92 EG with about 300hp. 1.7 60 footer on an old set of 24.5x8x13 mickey slicks. You def have the MPH to go really low 11's maybe even high 10's.
EVIL
Old Mar 18, 2005 | 04:11 PM
Flexmyrex's Avatar
Default Re: 11.4@126, can the time be improved? (Evil DOHC)
thank you all, i guess we'll put on the 24's and see what it can do.
Old Mar 18, 2005 | 06:30 PM
el arbi's Avatar
Goodluck. Impressive times
Old Mar 18, 2005 | 08:48 PM
mrbsponge's Avatar
i will say with the HP you have we are at the same spot, but i netted a 1.6 60ft, and ran a 7.14 1/8th mile, so if you were to come out the hole a little kwiker, you could drop the 1/4 ET down some, i know you can.
i was on 22x8x13s M&Hs
Honder07si
Honda Civic (2006 - 2015)
22
Sep 20, 2008 03:04 PM
Nextelbuddy
Jun 19, 2004 09:32 PM
HaTcH_BmX
Jul 18, 2003 03:34 PM
el arbi
Apr 29, 2003 07:19 AM
UCLAsi
Feb 28, 2002 08:58 AM
