type R crank shaft pulley on a EG??
Old Mar 16, 2005 | 03:50 PM
HULKHATCH10's Avatar
Default type R crank shaft pulley on a EG??
I was wondering can u use a type R c.s.p on a 94 EG ?? Im planning to delete my a/c and i ave no p.s will it work?? need ur help..
Old Mar 16, 2005 | 04:03 PM
Built to Spill's Avatar
el diablo
Default Re: type R crank shaft pulley on a EG?? (HULKHATCH10)
Stock motor?
Old Mar 16, 2005 | 04:08 PM
Default Re: type R crank shaft pulley on a EG?? (Built to Spill)
i have a d15b im gonna add headers, intake, cam gear , stage 1 clutch, mild stuff ....
Old Mar 16, 2005 | 04:17 PM
el diablo
Almost 100% this wont work. The only way i could see this working is with major modification.
Suggestion: Just get the correct pulley for your motor.
5wing's Avatar
For the amount of money you'll spend on those parts you might as well do a d16z6 swap, it'll probably be cheaper, definately quicker
Old Mar 16, 2005 | 04:25 PM
Default Re: type R crank shaft pulley on a EG?? (5wing)
i already got the engine , would a anothorodox pulley work fine
i guess type R pulley is out of the ebay buy list ...thanx i could of lost 65 bucks...
Old Mar 16, 2005 | 08:20 PM
soLSvtec12kcraze's Avatar
machine the stock one.....costs like $50 to cut the two belt tracks off, and have it balanced.
unorthadox doesnt have harmonic balancer....
Brown Rock
Dec 30, 2011 11:02 PM
jaap_15
Feb 17, 2011 09:25 PM
russianswty
Mar 6, 2007 07:02 PM
jdmbb6
Apr 26, 2005 12:00 AM
JSpecwest
Dec 26, 2001 10:02 AM
