turn signal fuse
hey guys I having a trouble with my driver front turn signal when I signal only the rear work but the front doesn;t not and it only the driver side because I think last time I put the wrong bulb which are different watt and I look under the dash and couldn't find the fuse for it OR do I have to check the fuse relay Im so confusing can anyone help me thank and I located the fuse relay but I can't take it out is like stuck or something I try pull it out but can't??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCeRTeG »</TD></TR><TR><TD CLASS="quote"> Im so confusing </TD></TR></TABLE>
yes that long sentence is very confusing.
as far as i know the relay should come right out, keep wiggling it
i don't think its your signal fuse if your rear blinkers work.
but in my '94 RS there's a 10 amp fuse for the turn signal off to the side of the main fuse cluster.
its labeled on the clear fuse sheet stuck to the fuse cover as 'TURN LIGHT' or something..
Mishima
Jun 30, 2009 09:08 PM
