Brake Help....
Old Mar 16, 2005 | 03:18 PM
ONEcam's Avatar
Default Brake Help....
Well heres the situation, i just did a brake swap [integra] into my civic and unfortunatly pass. side is bent and driver side caliper needs rebuild, i cant afford buying a rebuild caliper or have time to switch everything on the pass. side and yes im a dumbass for not checking it in the first place but watever.... Now my question is can i run my civic brakes with having the integra master cylinder, booster, and pp valve???
anyone????
Old Mar 16, 2005 | 03:36 PM
pdiggitydogg's Avatar
Yep, you can.
I was running ex/si calipers up front with an itr mc/bb/em1 prop valve.
Are you sure its not just the seals on the caliper that need replacing?
Old Mar 17, 2005 | 08:24 AM
ONEcam's Avatar
well driver side kept slowly locking up, so i assumed that its the caliper itself bc of how old the piece is and its condition, but i honestly dont know, right now i am running the DX brakes and after a while both of the brakes start to lock up as well... what do you thing it could be?i did adjust the booster
Old Mar 17, 2005 | 08:35 AM
could be a number of different things.
The problemt that you installed so many different things at once makes it hard to pinpoint.
Id start with the caliper itself as the issue and work from there...
Old Mar 17, 2005 | 09:07 AM
ONEcam's Avatar
Default Re: (pdiggitydogg)
what do u think is the reason why im locking up ...its it just becasue it distributing too much brake fluid and its causing it to do this, bc it does it to both sides on the dx brakes...whats ure full setup? [brake]
edit: it only starts locking up after i turn the car off....i dunno wat it could be
Modified by ONEcam at 2:44 AM 3/19/2005
Old Mar 18, 2005 | 05:44 PM
ONEcam's Avatar
anyone???
Old Mar 18, 2005 | 07:35 PM
93civicsedan's Avatar
Default Re: (ONEcam)
what booster and master cylinder combo are you using? if you mixed abs and non-abs mc and booster, your brakes will lock up. happened to me when i did the conversion.
Old Mar 19, 2005 | 04:35 PM
ONEcam's Avatar
rs mc with rs booster
Old Mar 22, 2005 | 06:03 PM
you should be fine with the RS setup. I have that in my car now.
Old Mar 24, 2005 | 04:20 PM
ONEcam's Avatar
figured it out.......faulty master cylinder.....advance auto sucks grande =====D
thanks though anyway for ure suggestions
streethondar
Jan 13, 2011 05:49 AM
flowgetta
Apr 16, 2009 12:09 PM
wideeg
Suspension & Brakes
Apr 8, 2009 08:51 PM
rollie_jimenez ef9
10
Nov 4, 2007 02:15 PM
89dxhunchback
Apr 5, 2005 02:05 PM
