B16A w/ B16 trans...Your RPMs at shift?
Old Mar 16, 2005 | 03:12 PM
blackrex's Avatar
Default B16A w/ B16 trans...Your RPMs at shift?
Friend of mine just got a car exactly like mine, and want to tell him everybodies opinion on this. Normally I'm shifting at around 7500 under hard acceleration, and I've heard of people shifting as early as 7000 and as late as 8200 before.
Old Mar 16, 2005 | 03:18 PM
BioXide02's Avatar
Default Re: B16A w/ B16 trans...Your RPMs at shift? (blackrex)
shift when you hit the rev limiter
Old Mar 16, 2005 | 03:20 PM
doublethink's Avatar
7800-8000 everytime.
i figure these stock internals dont make any real usable power beyond that anyway.
Old Mar 18, 2005 | 02:19 PM
jsw_1986's Avatar
Default Re: B16A w/ B16 trans...Your RPMs at shift? (doublethink)
I'de just shift when I started to feel a power difference. or you can go ahead and take it to 8k then when you hit the next gear you should be pretty close to hitting into vtec. whatever works. just tell your friend to take it to the track see what rpm's give him the best times.
Old Mar 18, 2005 | 02:54 PM
quik89's Avatar
Default Re: B16A w/ B16 trans...Your RPMs at shift? (jsw_1986)
i usually hit around 7800
Old Mar 18, 2005 | 04:24 PM
red_crx's Avatar
I usually take up to 8k
Old Mar 18, 2005 | 04:49 PM
Malgerus's Avatar
Default Re: (red_crx)
depends on the gaer
1st - 8000
2nd- 8200
3rd - 8300
4th - don't need to shift higher
Old Mar 18, 2005 | 05:29 PM
Burlyirishdude's Avatar
Default Re: (Mr. S)
1st gear - 7900-800
2nd gear - 8000
3rd gear - 7900
4th gear - 8000
5th gear - ****
Ys-1 tranny.....It doesn't matter how much you think you can keep up...with that gsr tranny it's gotta go the whole way on the real opponents...
Old Mar 18, 2005 | 05:36 PM
biggdogg's Avatar
Default Re: (Burlyirishdude)
y1 cable with ls 5th gear
1st 9500
2nd 9500
3rd 9500
4th 9500
ls 5th too scared to take it past 6500 . needle buried .
Old Mar 18, 2005 | 05:37 PM
PHOBIA's Avatar
my shift light is set at 8.2k but keep in mind. if your redlining every gear all day your going to get mad valve float and trust me, its not cheap to get your valves adjusted.
Just a n00b
Acura TSX
Jul 29, 2010 04:01 PM
SimplyTron
Apr 27, 2006 05:00 PM
pmachan
Jan 19, 2006 11:45 AM
Duckz
Dec 17, 2002 07:28 AM
