zc trans question
Old Mar 16, 2005 | 03:05 PM
messeduprex's Avatar
Default zc trans question
i know the zc trans uses an intermediate shaft but can you use it without one and use stock axels?
Old Mar 16, 2005 | 03:06 PM
Magick211's Avatar
Default Re: zc trans question (messeduprex)
nope, you cannot use your stock axles. And i bileve its because the part that goes into the tranny is a smaller diamater
Old Mar 16, 2005 | 03:10 PM
Default Re: zc trans question (Magick211)
thats what i thought thanks.
Old Mar 16, 2005 | 11:42 PM
Kwicko's Avatar
You CAN use your stock DX/Si axles and do away with the intermediate shaft, if you swap the ZC transmission's differential unit. I recommend swapping in an Si diff/final; it's got a more aggressive final drive ratio (4.250:1, versus the ZC's 3.88:1).
What I'm running in my '91 "DX/Si" (DX chassis, Si engine and interior):
ZC 1-4 gears
HF 5th gear
Si final/diff
It's all packed into your basic Si transmission case (pretty much any '88-'91 L3 tranny case will work), and it uses off-the-shelf Si axles. It accelerates a fair bit better than a stock Si.
Mike
Old Mar 17, 2005 | 01:06 AM
Nerologic's Avatar
Default Re: zc trans question (Kwicko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">nope, you cannot use your stock axles. And i bileve its because the part that goes into the tranny is a smaller diamater</TD></TR></TABLE>
you can use a zc tranny with stock axles theres 2 ways
this one:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwicko &raquo;</TD></TR><TR><TD CLASS="quote">You CAN use your stock DX/Si axles and do away with the intermediate shaft, if you swap the ZC transmission's differential unit. I recommend swapping in an Si diff/final; it's got a more aggressive final drive ratio (4.250:1, versus the ZC's 3.88:1).
ZC 1-4 gears
HF 5th gear
Si final/diff
Mike</TD></TR></TABLE>
and this one:
u get ur stock axles, and just replace BOTH inner joints on the stock si/dx axles with DA integra passenger side inners thats the EASY remidy other then hunting down the shaft
sodaZC
Feb 3, 2014 08:05 AM
Spazius
Jun 16, 2007 02:03 PM
nasteboyii
Jul 26, 2004 02:00 AM
Phoenix1
Nov 18, 2003 08:05 PM
Art T. Fish L.
23
Apr 6, 2002 09:27 AM
