Raising redline (b16a2)
I just installed itr cams in my car and want to raise my redline for as little $ as possible. I know i will have to replase my valvesprings (thinking omnipower) but will i also need new retainers because of the dual spring design. Also, how high of a redline can i risk without blue printing the bottom end/ installing new bearings. Finally anyone know of a cheap ecu option considering its OBDII and i dont want to have to buy a new ecu
if possible
thanks
if possiblethanks
first off with itr cams your power band does not go much higher so not really worth it to get springs and retainers.
second to be able to rev higher you would need a clip over to obd1 an obd1 ecu and you need it reprogrammed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accorse07 »</TD></TR><TR><TD CLASS="quote">
second to be able to rev higher you would need a clip over to obd1 an obd1 ecu and you need it reprogrammed...</TD></TR></TABLE>
Or you could just buy yourself a VAFC controller.
i think the most restictive part of the valvetrain is the head....porting/polishing works wonders...i mean there isnt really a cheap way to raise valvetrain and still make power unless you get some beefy cams/valvetrain/tuning then port the sheeat out of it
however, you can take itr cams up to the 9k range, but to see that youre gonna have to upgrade the valvetrain to ITRs at least. where you just got those cams if u throw in itr valvetrain with them youll notice the difference.
i second the vafc option tho...chips work for mild set ups, but full tuneability what more could you ask for (besides hondata)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCHIKANEdc2.0L »</TD></TR><TR><TD CLASS="quote">if you raise the rev limit past the powerband your motor will just rev and your car wont really be going anywhere. that sucks </TD></TR></TABLE>
Yea, I agree. Stock b16a2 limit is 8400, and that's just fine. Unless you have a lot of work done(cams, valvetrain, portwork), you won't be making any more power. I can rev mine to 8700 and I've done it many times but it doesn't make any more power than at 8400. If you look at a b16 dyno chart, max power is made around(don't quote me on this) 7800-8100.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_dohc »</TD></TR><TR><TD CLASS="quote">I can rev mine to 8700 and I've done it many times</TD></TR></TABLE>
You love your redline, dont ya, charles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">Or you could just buy yourself a VAFC controller.</TD></TR></TABLE>
A VAFC does nothing for a rev limit.
Contact http://www.locashracing.com. If you upgrade cams and raise rev limit, you're going to want to look into getting a set of better valve springs and retainers... at least ITR spec valvetrain.
Modified by LSVTEC 91 Civic at 12:42 PM 3/17/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
Modified by LSVTEC 91 Civic at 12:42 PM 3/17/2005</TD></TR></TABLE>
How's it like down there at 8000, Manny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_dohc »</TD></TR><TR><TD CLASS="quote">How's it like down there at 8000, Manny?</TD></TR></TABLE>
Stay on topic, n00b!
(F.Y.I. I make YOUR peak WHP at 5800 RPM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze »</TD></TR><TR><TD CLASS="quote">wtf does that have to do with redline?</TD></TR></TABLE>
It's basically saying that though my redline is much higher than his, he makes more power than I do(LSVTEC vs B16A2). That's what it has to do with redline..
