quick LS/Vtec question can u use the B18b headbolts... or what?
so just as the topic states do u have to use the vtec headbolts or does it matter if u use the ls headbolts cuz those things are about 100 bucks.. more then i would like to spend on this headswap im doing and i already have the complete B18b.. and it works fine.. how it is. help please
little confused about your question but i think you want to no which heabolts for your ls/vtec? if so im pretty sure you need to get the gsr ones bc there longer than the b16a bolts. get the arp ones well thats what i would do if it was me but its up to u. hope that helps
you cant use the LS head stud they are longer then the Vtec ones basically if you dont want to spend the money your in the wrong hobby not to be a *** but get APR ones spend the money its worth it in the end
ok so im using a B16a2 head on a B18b ls block and i want to get which ARP head stud exactly since im spending the money.. i just figured if i had the part why spend the money. which one is best to use thanks.
