JDM d15b motor
I bought a JDM d15b motor to put in my 95 SI hatch. What timing belt and water pump do I need to buy that fits on the d15b motor? I know the ones that fit the d16z6 wont work. What changes will I have to make to put this motor in? I know I have to swap the intake & exhaust manifolds and the distributor. What else will need to be done?
TRY FROM A 92-95 DX 1.5 FOR THE TIMING BELTSINCE THE 1.6 DOESN'T FIT AND THE WATER PUMP SHOULD BE THE SAME. MAYBE SOMEONE WILL HAVE ONE LYING AROUND FOR TEST FITTIMENT. AND YOU DON'T NEED TO SWAP THE MANIFOLDS OR SENSORS BECAUSE YOUR CAR IS ALREADY OBD1.
well, i found out today that the company mis-informed me on the motor. i bought a jdm d15b w/o vtec when it was suppose to have vtec. they wont take the motor back b/c they claim that i knew about it being non vtec. so can i use this block on my z6 head? what all would i need to do to complete this swap?
DUDE YOUR TELLING ME WHEN YOU FIRST LOOKED AT THE MOTOR YOU DIDN'T NOTICE A VTEC SOLENOID MISSING. NEXT TIME DO SOME RESEARCH BEFORE BUYING A MOTOR. I HAVE NO SUGGESTIONS FOR YOU BESIDES A THE MINI ME SEARCH AND SEE WHAT COMES UP.
Modified by dnoredsi at 10:54 AM 3/23/2005
thatbluecrx
Mar 22, 2005 02:19 PM
