Passing Ca smog with fuel hondata;1:1 reg
Ok, I was turbo but now I have all the stock stuff back on. But I cant find my stock rail, injectors and egr valve. So, my question is will I pass smog, specifically the visual. I have hondata s200b, 440 precision injectors and an aero-motive 1:1 regulatior. I am pretty sure I will pass the test if I can just get my car on the sniffer. Any help will be great. Oh, this is in San Diego if that makes a difference. Thanks
You won't pass the visual if you do not have your EGR valve installed. If your car is OBDII, it won't pass the OBDII scan check with an OBDI ECU in the car.
Can you install the egr valve onto a aftermarket (read AEM) fuel rail? Sorry, it has been so long since I looked at a stock h22 I cant even remember what the egr valve hooks up to or does. Thanks
Got Honda
Mar 13, 2003 03:55 PM
