sohc zc cam in d15b1 head
im pretty sure this will work, but im not 100% sure. will it? can i use my stock sprocket or will i need an si or zc one? i understand that the b1 has a crappy, lame cam and i want some more hp. by the way, car has cat-back and mpfi swap. will i notice the difference?
yes you can use the zc sohc cam with current setup and parts. you might as well adjust valves if needed since the valve cover is off.
you will notice a bigger difference. since its more agressive then the d16a6 si one.
get an FPR to bump up fuel pressure and advance ignition abit for more power.
Bump because I've always wanted to do this. **** i already beat 2 auto EXs. Not kidding.
I always read that you have to get an adjustable cam gear tho.
