Toda Racing Spec A cams
Old Mar 16, 2005 | 06:14 AM
RicTRD's Avatar
Default Toda Racing Spec A cams
Is anyone using Toda Spec A cams? is the power gain really noticeable? please give your pros and cons
Ric
Old Mar 16, 2005 | 06:20 AM
Flux's Avatar
Default Re: Toda Racing Spec A cams (RicTRD)
I have the Spec A TODA cams and I love them. Yes the gain is noticeable for sure. The Spec A is a mild cam, so there are other setups out there that will make more power for sure, but one bonus of the Spec A is reliability and ease of use. These things make a nice power curve on stock internals and stock compression.
Old Mar 16, 2005 | 06:22 AM
Black R's Avatar
25 Year Member
ditto.
Old Mar 16, 2005 | 09:56 AM
CNSK's Avatar
Default Re: Toda Racing Spec A cams (Flux)
I have a jdm type R and can the stock itr valvetrain be able to handle spec b cams? or should I just stick with A?
Old Mar 16, 2005 | 11:32 AM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicTRD &raquo;</TD></TR><TR><TD CLASS="quote">Is anyone using Toda Spec A cams? is the power gain really noticeable? please give your pros and cons
Ric</TD></TR></TABLE>
Yes as long as you get them tuned. When I installed mine, the car felt the same until it was tuned.
Old Mar 16, 2005 | 11:59 AM
RicTRD's Avatar
Default Re: Toda Racing Spec A cams (GeeReg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeReg &raquo;</TD></TR><TR><TD CLASS="quote">
Yes as long as you get them tuned. When I installed mine, the car felt the same until it was tuned.</TD></TR></TABLE>
How did you tuned them to feel the difference in power gain? with the cam gear? how many degrees did you advance or retard in intake and exhaust?
Old Mar 16, 2005 | 12:11 PM
Flux's Avatar
Mine are tuned with both the cam gears and a VAFC. I do not know the degrees of adjustment of the cam gears...
Old Mar 16, 2005 | 12:12 PM
Type-R Yo!'s Avatar
New User
You it with vafc or EMS or Power FC or Hondata or uber data, cam gear and FPR stuff like that.
Old Mar 16, 2005 | 01:43 PM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicTRD &raquo;</TD></TR><TR><TD CLASS="quote">How did you tuned them to feel the difference in power gain? with the cam gear? how many degrees did you advance or retard in intake and exhaust?</TD></TR></TABLE>
With my particular setup the intake is advanced 4 deg and I forget where the exhaust is. This doesn't mean it will work for you though. Also like Type-R Yo! said, you need some type of fuel tuning.
.Mason
Apr 11, 2008 08:53 AM
hqrcrx
Dec 10, 2004 06:48 PM
slopez007
Nov 26, 2004 07:11 PM
rev210k
Jun 30, 2004 12:24 AM
al'motormadness
May 30, 2003 09:30 AM
