96-98 ex engine harness needed HELP!, 00 b16a2 swap question, 97 cx hatch....
Old Mar 16, 2005 | 05:57 AM
nahmanitscool's Avatar
Default 96-98 ex engine harness needed HELP!, 00 b16a2 swap question, 97 cx hatch....
so i have a 97 cx hatchback, and i bought what i thought was a complete 00 b16a2.. so i pull out my stock cx engine, which already sold, cuz i had a new wire harness attached to the b16. so i cant use the cx harness for modifcation anymore (to run vtec) well the b16s wire harness only has 2 ecu plugs on the engine side of the harness. THEY DID NOT TELL ME THIS they said it would plug right in to my stock 97 ecu, which is not true since the 99-00 si had the third plug on the dash harness. the only way i found around this problem is getting a 96-98 ex wire harness which has all 3 plugs on the engine harness, and is already wired for vtec.
So i need a 96-98 ex engine harness...anyone have one? ive been looking everywhere.
or does anyone else know away around this? my car is going on its second week of being down.
any help is appreciated... thanks
Old Mar 19, 2005 | 03:40 PM
no help here? anyone.
Old Mar 19, 2005 | 03:51 PM
93Civac's Avatar
I dont have one, but your best bet is to find a 96 to 98 EX harness. You have to extend a few wires but everything plugs up.
Also you cant really use the 97CX ecu. You will need to get a ecu thats been chipped or one that is for an obd2 b16/b18.
Old Mar 19, 2005 | 04:37 PM
yeah thats what ive been told... and im looking for one. but what wires need to be extended.. i already ordered a chipped p28 and jumper harness. i just need to find the ex harness now.
Old Mar 19, 2005 | 08:37 PM
93Civac's Avatar
the vtec wires need to be extended, since the vtec solenoid is in the front of the distributor on the b16. I think thers one other wire that I extended but ill have to look. If your using the b16 stock manifold you will have to extend the o2 sensor wires or you can just unwrap the tape and pull the wires back so they will reach the back side of the engine. I think everything else will plug up. Im doing a b16a2 swap out of a 2000 SI in my 96 hatch and I am using the EX harness. I will look at my engine in the morning and see if there was anything else that needed to be done. I can take some pictures if you need also.
Old Mar 20, 2005 | 03:02 AM
awesome man. yeah im doing a 00 b16a2 swap in my 97, the engine has been sitting on the ground next to the car for about two weeks now, cuz i cant find this damn harness. where did you get yours?
Old Mar 20, 2005 | 12:04 PM
93Civac's Avatar
Default Re: (nahmanitscool)
I found my harness in the classified section.
Old Mar 20, 2005 | 12:40 PM
****...sucks being a n00b on this board haha.
Old Mar 20, 2005 | 05:55 PM
93Civac's Avatar
Yeah, ill keep an eye out for one, ill let you know if I find one.
Old Mar 21, 2005 | 04:07 AM
thanks alot man.. thats awesome.
Old Mar 21, 2005 | 05:33 AM
Evil-EK's Avatar
Call hilltop honda salvage. 423-928-4469 You should be able to get one shipped for around 150. Ask for Buck and tell him Billy told you to call.
Old Mar 21, 2005 | 05:52 AM
DizzleSizzle's Avatar
Default Re: (BigBlockH22atch)
go to this website they have plenty just make sure u get one for M/T
http://www.car-part.com/cgi-bin/search.cgi
Old Mar 22, 2005 | 07:07 AM
hey 93civac... i got an ex harness but im having a few problems.. did you have change a plug at all.. like the one that is parallel to the timing belt cover? i have nothing on the ex harness that matches that plug, its the on the furthest side of the engine near the altenator... let me know man.. im hoping this **** works out.
Old Mar 22, 2005 | 01:58 PM
93Civac's Avatar
I think the plug your taliking about goes to the crank fluctuation sensor (sp). Ill go take a pic of mine and we will see.
Old Mar 22, 2005 | 02:22 PM
93Civac's Avatar
Default Re: (93Civac)
Ok. Is it the plug that I have circled in red? If it is then that plug goes to the Crank fuctuation (sp) sensor, and it would plug into the one I have circled in blue. The plugs are different and you can rewire it so it will plug in, but since your using a p28 ecu there is no need to do so. The p28 doesnt look for that sensor so you dont have to plug it in.
You may also have a grey plug on the back of the engine that has one green wire and one black wire. That plug goes to the power steering preasure switch (at least that is what I was told). If you have power steering then it should hook up somewhere but if you dont you can just tape it up out the way. Here is a pic of the one on the back of my engine, the wire is long because i had to splice it on due to a broke plug, I circled it also.
Old Mar 22, 2005 | 02:47 PM
hey man the pics didnt work...also did you only have 1 o2 sensor or 2? and on the harness going back towards the firewall where the plugs go into the car there is another plug that i dont know where goes.
Old Mar 22, 2005 | 02:54 PM
haha i refreshed the page and the pics work.. anyway. yeah thats the right one.. what wires do you splice together cuz the crank sensor has two.. and the other plug has 3? also did you only have one o2 sensor? i was told there was supposed to be two. thats why i thought that long wire was the secondary o2 sensor, which is supposed to plug into the cat, and the primary plus into the downpipe on the headers, like in the pic. but then there is one plug i dont know about still that i mentioned previously.
Old Mar 22, 2005 | 03:28 PM
93Civac's Avatar
You dont have to rewire the crank sensor because the p28 ecu doesnt look for it. Also the p28 ecu doesnt look for the second 02 sensor so no need to worry about it either.
What color is the plug that is near the firewall? If is kinda big and brown it doesnt plug in anywhere. Its just there.
Old Mar 22, 2005 | 03:32 PM
93Civac's Avatar
Also there isnt any wireing on the EX harness for the second 02 sensor because the wireing actually comes out the body underneath the car by the catalytic converter. My hatch and yours have the catalytic converter on the manifold and thats the reason we have the second 02 sensor in the factory cx harness.
Old Mar 23, 2005 | 10:08 AM
the plug i am talking about comes off the harness near the same place as the wire that goes to the fuse box. i dont see any place it plugs into.
Old Mar 23, 2005 | 01:14 PM
lactoselobster's Avatar
hey man this is hoogaface..........that black plug in the last pic goes to the intake sensor that obd2 cars have if you are going to run a chipped p28 dont worry about it the computer will not look for it............
E.46
Apr 15, 2006 11:41 PM
91blksi
Feb 14, 2006 10:31 PM
redboost10
Feb 8, 2005 08:20 AM
94_civicEx
May 14, 2004 06:11 AM
89JDMcrx
Feb 21, 2003 05:04 PM
