Priming the Car
Old Mar 16, 2005 | 05:07 AM
ThaMatrix's Avatar
Default Priming the Car
I have a Rex and i want to prime it my self and get all the dings out.. i was wondering if anyone here knew what process i would need to go through...
Old Mar 16, 2005 | 05:09 AM
jakeiscool's Avatar
Banned
Default Re: Priming the Car (ThaMatrix)
sand the whole car down with 180-200 grit, just sand down through the clear and the first coat of base. If you are going to put body filler over a ding or dent, sand down the whole area around it (5 inch radius) to bare metal, the reason for doing this is that body filler will peel and flake if you apply it to any layer of paint. Once you are done with the dings and dents, prime the panels that have body filler on them, block sand them with 240 grit. You dont need to prime any panel unless it has body filler on it. Who ever paints it will seal the entire car with a yellowish sealer. Good luck.
Old Mar 16, 2005 | 05:12 AM
ThaMatrix's Avatar
Default Re: Priming the Car (JakeIsCool)
thanx
Old Mar 16, 2005 | 03:47 PM
ThaMatrix's Avatar
bump
Old Mar 16, 2005 | 03:50 PM
Built to Spill's Avatar
el diablo
SEARCH! derp!
G3teg96
Paint and Body
14
Aug 27, 2011 02:39 AM
-16V-
Paint and Body
Mar 15, 2009 06:35 PM
enhancedCL9
Nov 8, 2005 08:00 PM
