smoke coming from engine bay
Old Mar 16, 2005 | 04:28 AM
efiv5lude's Avatar
Default smoke coming from engine bay
I have a 97 base prelude, after hitting vtec (shifting at 7k) i started to smell a funny burning smell, almost like oil and antifreeze together. i checked under the hood and there was smoke all in the engine bay, not a lot like in the first fast and furious, but a decent amount. I'm not sure what the problem is.
Old Mar 16, 2005 | 09:20 AM
SiRLudeVtec's Avatar
Default Re: smoke coming from engine bay (efiv5lude)
Well - maybe you ran the car too hard and the antifreeze squirted out onto the head....and since the head is hot, it burned the antifreeze to make smoke? Maybe you have a faulty reserve tank for the antifreeze - i did this once driving my fourth gen - but i was running it REALLY hard - but if there was oil or antifreeze on the valve cover, it might not be much to worry about.
Old Mar 16, 2005 | 09:32 AM
98TypeSH's Avatar
Default Re: smoke coming from engine bay (AJBurks)
when the car is cool, pull off the radiator cap (while the car is off)
Start the car with the cap off and check to see if your coolant is black or if there are metal flakes or anything of that sort on the cap. If there is these are signs of a blown head gasket. Also check your oil. If it has a white/milky appearance the head gasket is toast.
Old Mar 16, 2005 | 12:22 PM
Default Re: smoke coming from engine bay (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">when the car is cool, pull off the radiator cap (while the car is off)
Start the car with the cap off and check to see if your coolant is black or if there are metal flakes or anything of that sort on the cap. If there is these are signs of a blown head gasket. Also check your oil. If it has a white/milky appearance the head gasket is toast.</TD></TR></TABLE>
Great way to put it...."TOAST"
futurefastguy
May 2, 2009 10:33 PM
johnca
Mar 22, 2006 12:32 PM
Mr_Moos
Mar 10, 2006 02:27 PM
EF7
Dec 15, 2005 05:23 AM
dragon659
Sep 29, 2003 04:39 PM
